Results 1 to 8 of 8
    13th October 06
    Atlanta, GA
    What's the proper iron setting
    for touching up the pleats on a PV casual kilt?
    16th September 06
    Manassas, VA, USA
    My PV kilt is a different brand, but my tag says low heat on the iron. I think that's pretty standard advice for acrylics.
    Paul X. Danner
    My Email
    13th October 06
    Atlanta, GA
    Thanks Paul, I will stick with the lowest setting and press on!
    You only need to steam the pleats. Get a Gizmo or similar hand steamer, you'll love it for your USA Kilts PVs.
    If you absolutely insist on trying to iron the kilt don't use the ironing board, follow Ham's advice and do it on the floor
    8th February 04
    2 little notes...
    1. STEAM the HECK out of it. Make sure your iron is set to a steam setting and go to town. Also, the iron should be on a MED setting. NOT the highest setting (you'll burn the material and make it "shiny") and not the lowest (steam won't come out and you'll end up standing there trying to get the creases out with a luke warm iron).
    2. If you have carpet, do NOT IRON on the floor... if the iron gets too hot, you can (depending on what kind of carpet and the kind of synthetic/real fibers it has) MELT the carpet and mess up your kilt! That goes for BOTH Wool and PV Kilts.
    24th November 05
    Clodine, Texas
    Here's a couple suggestions on ironing kilts. If you must use the floor, don't do it on carpet, find a hard floor, or other big flat surface, (I use the dining table at home) and then fold a bed sheet so you have 2 or 3 layers of material to kind of pad and protect the surface, and keep the kilt clean. Then iron away!
    16th August 06
    Salt Lake City, UT
    I've been using the kitchen table with a towel laid out on it as a cushion and protection to the table. It's way easier than the ironing board.
    I use the iron as hot as it can get, BUT...I never let the iron touch the fabric itself. I use a fairly wet (just wrung out) washcloth and use it to steam the fabric. Steam it till there isn't much water left in the washcloth. It works great and I haven't hurt anything yet.
    I agree with keeping the heat low if you are going at it directly.
    5th September 05
    Chicago
    I have some scrap pieces of cotton duck left over from stretching canvses for painting and those get recycled as pressing cloths..steam goes through but surface of the iron never actually touches the fabric.
    And I'll second that thought about ironing boards...how can you get a kilt to sit evenly on an ironing board?
    Best
    AA
