13th January 07, 11:15 PM
How low should it go?? Sporran that is.
Been trying to find the right place for the sporran. If it's too low in the front, it bangs from leg to leg when I walk. If it's too high, then it doesn't help to weigh down the aprons when I sit. Maybe it just takes practice to find the right spot. Any advice?http://www.xmarksthescot.com/forum/i...n_rolleyes.gif
14th January 07, 12:28 AM
The traditional place is over the genitals.
I have read that it evolved from a piece of armor that protected them, but don't remember where. Could be more fanciful history.
14th January 07, 01:03 AM
The sporran is not what causes the apron to fall between your legs when sitting you use your hand to do that.
Many new people wear their sporran too low. It should not bang your legs or swing around wildly when walking. It should also not cause your aprons to bunch up under the sporran. If you find you need to smooth your apron after a few minutes of moving, your sporran is probably too low. A good rule of thumb is;
With the kilt at normal, traditional height, above the naval, your sporran should hang just under your naval and just above your genitals.
I suggest you take a look at Hamish's photo albums. Anytime I have a question about the proper and/or appropriate wear of the kilt I look at how Hamish does it first. Then I go from there.
You can also look at Hamish's video on sweeping the pleats and sitting which is a sticky post here.
14th January 07, 04:06 AM
I was always taught a hand's breadth beneath the belt buckle. However, I've found that being a bit bulkier than a traditional piper, I wear it better a bit higher than that, so it doesn't accentuate that feature of my anatomy.
As for sitting, I spread my legs then close them, to draw slack into the aprons. The sporran only comes into play with my horeshair.
14th January 07, 04:18 AM
I would second that, anytime I have a query as to whether I am wearing something correctly all I have to do is check out Hamish's photo album
here is the link:
http://hamish.imff.net
14th January 07, 07:14 AM
The top of my sporran sits 2 inches below my navel. Or there abouts. I am kinda a big fellow, and this keeps things from bunching up when I move or banging around when I walk.
14th January 07, 08:32 AM
This is how I tell people to wear it... 4 fingers below the buckle as a rule of thumb.
14th January 07, 08:36 AM
If I wore my sporran the full width of my hand below a belt it would hang way to low.
Always remember there are exceptions!
14th January 07, 09:08 AM
that's the rule I use. Any further down and my legs get a beating. Highter and it winds up being a second belt.
14th January 07, 10:38 AM
I simply wear my sporrans where they feel comfortable. The "hand's width below the belt" is a good starting point, and adjust from there. My different sporrans each have a "sweet spot" where they hang, and they are each a little different, since they're each shaped differently. I have a different sporran strap for each. I've made use of a leather punch to put buckle holes in exactly the spot where they're comfortable.
Andrew.
Last Post: 2nd December 04, 04:52 PM
