Results 1 to 9 of 9
    10th March 07
    Tips on making a Fly Plaid
    Hi there.
    My father and I both have some lovely and unusual Macdonald Modern dress kilts that we really like. They were bought cheaply on Ebay to wear at my cousin's wedding. (All of her male guests were wearing the pride of Scotland tartan, but my Dad and I wanted to go with our family tartan and found that this one looked similar enough that it wouldn't be out of place in the photographs.)
    A short while ago, we decided to make fly-plaids to go as we have them for our other kilts, but couldn't find them anywhere.
    I managed to buy another of the kilts from Ebay and have picked it appart and pressed it and found that there is more than enough material to make two fly plaids.
    Now, I'm terrible at hand-sewing, but my Mum has decided to help me out and let me use her sewing machine to make them.
    So, does anyone have a few instructions on how to make a decent fly-plaid that will hang well?
    Many thanks.
    25th May 06
    Kitchener, Ontario, Canada
    Dia Dhuit, Arlen!
    Fly Plaids typically come in two different sizes: 39" (99 cm) square or 54" (137 cm) square.
    They are fringed on all four sides in one of two ways:
    Standard fringe: involves pulling out threads to achieve the desired length of fringe (not too long, else it will get ratty quickly).
    Purled fringe: This requires much more effort, as you must pull out more threads than the standard method. Then, you must twist the threads together and tie them in an overhand knot at the end. Much like the finished end of some blankets.
    As for sewing, it's really your choice. Some kilt makers sew one corner into folds/pleats. This is the corner which passes under your epaulette. Other kilt makers, like myself, don't bother. By leaving it square it can be ironed in the future and it can still be used as a shawl or wrap if need be.
    Uh . . . I just re-read you post and realised you had dismantled a kilt for the material. Unless it was made for an extremely tall person (8' + tall ) it won't yield a sufficiently wide enough piece for a fly plaid. However, you could probably make some sort of day plaid out of it.
    Hope this helps!
    Owner/Kiltmaker - Keltoi
    10th March 07
    Quote Originally Posted by slohairt View Post
    Dia Dhuit, Arlen!
    Hope this helps!
    Well, I might not be able to make a proper fly plaid, but hopefully I can at least make a passable day plaid.
    Thanks for the really good advice. If nothing else, it's a project to learn from.
    21st November 06
    Margaritaville
    Mine are both 54" X 54", with a 1" fringe. The store-boght one has a corner that's been pleated and stitched, the one that I made does not.
    Having worn them both, I really can't say that the stitched-in pleat at one corner is important to me, and I wanted to be able to fold it flat, as an Irish brat (or a day plaid), so no sewing's involved.
    I marked 1" in on the blade of a pair of shears, and made a series of 1" deep cuts along an edge; mybe 4" - 6" or so. Then I spent a loong time on the couch with a sailmakers needle tatting out the threads. I've been quite happy with the result; wore it yesterday, and will again tonight (I'm wearing it in my avatar).
    10th March 07
    Quote Originally Posted by PiobBear View Post
    Sounds like a lot of work, but from what I can see it looks really good.
    The amount of material I've got is very narrow, so it'll be a daywear thing at best, but it's practice.
    Thanks for the info.
    21st November 06
    Margaritaville
    It's not hard to do, but it is tedious. However, a fringe less than 1" just doesn't look right to me, and the result is worth it.
    5th January 06
    Manteca, California
    Fringing
    Quote Originally Posted by Arlen View Post
    Try this post for intructions on purling.
    http://www.xmarksthescot.com/forum/s...ad.php?t=16689
    I've done it a couple of times now as practice for making a full fly plaid.
    w2f
    10th March 07
    I concur. Small fringes just look wrong.
    10th March 07
    Quote Originally Posted by way2fractious View Post
    w2f
    This is great, thanks. I'm hoping to have it done by the end of the week.
  1. Holiday eating tips...
    By Mr. Kilt in forum Miscellaneous Forum
    Last Post: 4th December 06, 09:32 PM
  2. A plaid moment
    By SSgt Baloo in forum Miscellaneous Forum
    Last Post: 11th September 06, 12:18 AM
  3. tips for a great kilt n00b?!
    By Andrew Green in forum Kilt Advice
    Last Post: 1st August 06, 05:53 AM
  4. tips
    By Josh_E in forum Kilt Advice
    Last Post: 14th March 06, 01:56 PM
  5. Making a mini fly plaid
    Last Post: 30th November 04, 10:52 AM
