Results 1 to 10 of 11
    10th March 07
    Newark
    how to make the sgian dubh stay in the scabbard?
    my sgain dubh is too lose for my likings in the scabbard so if anyone knows how to fix this please tell me.
    27th October 06
    Snellville, Ga
    What I did was buy a piece of stiff felt from a local craft store. Cut it to fit the slot in the scabbard (you might need to cut it long and fold it in half if the slop is too much).
    27th January 05
    Jefferson, Georgia, USA
    The advise Splash gives is probably the best option. I think someone else used a piece of card board if you only need to shim it a little.
    10th March 07
    redding,CA
    some scrap sweade leather and a little glue will work wonders also.
    21st November 06
    Margaritaville
    In addition to shimming the scabbard, most folks I know wear a sgian with only the top half of the hilt exposed, with the hose top holding it in place. I believe that there's a reliably reproducible inverse relationship between a sgian dubh's cost and the height at which it is displayed.
    18th April 06
    Phoenix Metro Area, AZ, US
    Quote Originally Posted by PiobBear View Post
    Agreed - all that needs to be showing is enough to grab the pommel with a thumb and two fingers.
    I've put in a lttle shim of stiff vinyl and it did the trick.
    As an aside the cashier in Home Depot yesterday stared at my kilted outfit with a dumbfounded look. She pointed at my sgian dubh and asked "What's that?" When I told her in was a knife that kilt wearers traditionally wear in their sock. She looked at me for a minute thinking and then said "but doesn't it hurt when you stick it in there?"
    Panache
    I did assure her that generally they are worn with a sheath.
    27th March 06
    Ferintosh, Dumfries, Scotland
    Quote Originally Posted by shane the piper View Post
    lose?
    surely ya mean "loose"...
    14th January 07
    I would consider adding the felt as a shim and to put a light coating of WD-40 or silicone spray on the felt. This would be light so it did not soak through the sheath but would coat the blade as it goes in and out.
    I would have to remember to wipe the blade before cutting the Haggis.
    18th April 06
    Quote Originally Posted by cacunn View Post
    WD-40's actually not all that good at preventing rust. It's a penetrating solvent, good for removing oils, greases, and other gunk that has accumulated gunk and gummed up the works.
    A light coating of microcrystalline wax or mineral oil would do better. Even a swipe of Vaseline.
  1. new sgian dubh
    By Buddha in forum How to Accessorize your Kilt
    Last Post: 16th April 08, 11:18 PM
  2. Sgian Dubh Two
    By O'Neille in forum DIY Showroom
    Last Post: 8th April 07, 03:07 AM
  3. This'll make a fine sgian dhu!
    By Woodsheal in forum How to Accessorize your Kilt
    Last Post: 9th May 06, 03:50 PM
  4. Sgian Dubh
    By calmac in forum How to Accessorize your Kilt
    Last Post: 31st January 06, 12:27 AM
  5. Sgian Dubh Appropriate?
    By Rubber Soul in forum How to Accessorize your Kilt
    Last Post: 12th January 05, 03:04 PM
