Results 1 to 6 of 6
    3rd January 07
    Sydney, Australia
    Two kilts compared:
    A Neokilt and a Sportkilt.
    I'm beginning to understand a few things about garments that I hadn't previously been aware of. It's the sort of knowledge that explains why there are so many different ways to make an unbifurcated garment compared to a bifurcated one.
    Both of my kilts are lovely, but they are quite different. Putting the Sportkilt on and I can immediately see the difference in their cut. The way the top apron folds is quite different, just for one example. I should mention that the Sportkilt is poly/cotton and the Neokilt is poly-viscose. The difference in the fabric is quite apparant and I can now understand why wool is usually chosen for a kilt; the Sportkilt is actually very light and the Neokilt is a little stiff.
    Actually, I found myself almost wishing for a combination of features, such as the elastic and the slightly lower wasitline of the Sportkilt on the Neokilt. And pockets! Neokilt has two little pockets that are not of a great use, and the Sportkilt has one in the middle that is unfortunately almost impossible to use. A friend commented about the Neokilt also commented favourably about the pockets (adding how hard it was to find skirts with good pockets). I know Utilikilt do pockets; surely they are not so hard to put into a more traditional design? Admittedly, what Neokilt did is quite clever, hidden in the depths of the pleats, but they need to be higher and deeper.
    So I now have an appreciation of kiltmaker preferences!
    Wade.
    * Yes, I can probably find someone who does that.
    30th June 04
    Houston, Texas
    Ditto on the Neokilt pockets. A good idea, but the execution doesn't really impress me. Now, the pockets I'm looking forward to trying out are the ones the Wizard of BC puts in his kilts; it's just a matter of time.
    22nd January 04
    Southwestern Ontario
    Anyone interested in kilt construction in general should invest in Barb Tewksbury's book on kiltmaking. It will provide a benchmark by which the various variants on the market can be evaluated with some good background knowledge.
    14th September 06
    South Central Missouri
    Congratulations on starting down that long path of kilt knowledge!
    "Knowledge is good." Emil Faber
    22nd September 06
    The Banana Belt
    For what it's worth, there are times the pockets on my UKs (workman, mocker, and denim) are too deep - I think I'd like one front pocket to be shallower, which wouldn't be visible in the mocker, at least.
    Frog
    8th February 04
    If you have a sewing machine (or know someone that does), just sew a line ON THE POCKET ONLY at the desired pocket depth and the pocket will be a little more useful.
  1. Traditional kilts vs. modern and casual kilts
    By Beery in forum General Kilt Talk
    Last Post: 7th September 08, 12:40 PM
  2. casual kilts, work kilts, and nice kilts
    Last Post: 1st June 07, 01:51 PM
