Results 1 to 10 of 15
    30th December 06
    Machine stitches that look hand-sewn
    Hi All,
    I came across some machine stitching on one of my kilts that looks like it was hand-sewn. I bought a black kilt off eBay a while back that was too long. I knew it would be, but the price was so low that I figured I could just hem it & save a lot of money. After it arrived, I saw that it's embroidered logo (where the kilt pin goes) was too close to the selvedge.
    So, after building my first kilt, I had the confidence to tackle it from the top. After dismantling the top of the kilt, I opened up the seam to put in the new strap hole & found, to my surprise that it had been machine stitched. From the outside it looks just like hand stitches, but there are 2 interlocking threads in there.
    It's a bit difficult to see because it is black on black. My question is; how was it done & can we do it ourselves without having to buy an industrial robot?
    18th December 06
    Burlington, Ontario, Canada
    We have our own crests made up for my Coast guard unit. All we have is a floppy disc with the coded instruction for an embroidery machine. Several places can do embroidery such as Stitch-It (found in most malls in Ontario) they also have numerous patterns already, you may luck out and find designs such as the rampant lion and such.
    30th December 06
    I had looked into that possibility, but I guess I didn't look hard enough.
    Can't do that now as I have cut 2" off the top already.
    18th December 06
    Quote Originally Posted by JohnH View Post
    I believe that this is the proper way to shorten a kilt though. Besides you keep the original embroidery and selvage.
    22nd January 07
    Morganton, North Carolina
    Machine Stitching on Pleats?
    Is there anyone out there with info about machine sewing the pleats in a way that looks like hand-sewing? I've sewn lower priced kilts which are topsewn down the edge of the pleat. But I've also seen kilts where the stitching on the pleats is basically invisible. Closer inspection makes it seem like the stitching is by machine.
    Cordially,
    David
    18th December 06
    I don't think that machine stitching will ever look like hand sewn. Hand sewn pulls the thread into to fabric that a machine can't. The only hing you can do is to get thread that matches as close as possible the colour of the fabric. Also sew the visible portion of the pleat face up as the underside is never as neat as the top side. And try a longer stitch.
    14th December 05
    Coeur d Alene, ID
    Ask Rocky - he knows...
    Actually that technique is used by many kiltmakers who machine sew but don't want anyone to know. It involves laying the fabric good face to good face so that they are aligned properly for the taper, making a line of stitching, then folding the pleat back to cover the stitches.
    It takes quite the finesse to get everything aligned blind. Rocky is a master at it.
    30th December 06
    Thanks Steve, I thought it might be like that, but decided that you could only do it with an exotic machine. It really does look very convincing.
    8th February 04
    It's not that people (like me) that machine sew don't want people to know, we just want to hide the stitches as best we can. Sewing "inside out" as I call it, works very well for that.
    Basically, you have to put the "good sides" together and match up the horizontal stripes. Then you have to pin each one down (using about 10 pins) to make sure it doesn't shift. Sew the line and open up the fabric. If the horizontal lines give a "stair" effect (i.e. they don't match up perfectly), you have to rip out the pleat (and all the work you just did) and re-do it. My rule of thumb is if the lines are off by 2 threads or more, it should be re-done.
    It takes me about the same ammount of time to make a kilt this way as it does Barb... we had this discussion when she came into the shop last August. I machine sew as much of a Premier as I can b/c I hate hand sewing. I can't avoid it on the horsehair canvas reinforcement or the lining, but I CAN do it on the pleats without showing stitches.
  1. Machine sewn pleats - fell to waist or...
    By pdcorlis in forum DIY Showroom
    Last Post: 27th January 07, 08:42 PM
  2. Hand Sewn, but where?
    By Improv1 in forum Traditional Kilt Wear
    Last Post: 28th December 06, 03:05 PM
  3. Why hand-sewn?
    By GTRMAN in forum Traditional Kilt Wear
    Last Post: 4th September 06, 11:43 AM
  4. Hand sewn vs. machine sewn
    By Manu in forum General Kilt Talk
    Last Post: 15th March 06, 04:04 PM
  5. Disapointed With an 800 Dollar Hand Sewn.
    By Dreadbelly in forum Traditional Kilt Wear
    Last Post: 8th September 04, 06:44 PM
