Cost?
How much should I expect to pay for a chunk of tartan, as would be used for a great kilt? I'm headed to a RenFaire in a little over a month, and just wondering so I can adjust my budget accordingly.
Thanks in advance.
~Yeti
Well, let's say there a COUPLE different kind of animals:
"Saxony," which is the "fuzzy" stuff and MUCH cheaper. It can be had for between $10-25/yard and up, depending on your source. The WEIGHT varies from very thin (used as a bunting substitute) to rather heavy (used for heavy wool bankets) and various "hands" (the feel and texture of the surface).
Worsted is the "correct" material used for nicer kilts. Typical "kilt weight" is between 13 and 16 oz. Regiments use(d) between 18 and 22oz. Some use lighter (9-11oz), but it does not hold a pleat as well, not "stay down" as well either. 13-16 oz is typically around 50-100/yard, depending on weight, mill, and retail source. Usually, the wholesale cost is only marginally lower than retail (often 2/3 final price or more expensive).
So, a 4 yard belted plaid could be anywhere from $40-50 for cheaper saxony to $400 or more. It ALL depends upon the quality of the cloth and yardage needed.
For a beginner, it may be best to buy your belted plaid from someone selling them specifically as such, say the Celtic Croft or the Tartan Museum. If you then want another, you'll have some experience in what you're looking for.
By Caberjames in forum Traditional Kilt Wear
Last Post: 28th October 06, 02:41 PM
By James in forum General Kilt Talk
Last Post: 1st August 05, 06:41 AM
By Galant in forum General Kilt Talk
Last Post: 29th July 05, 03:13 PM
By Jimmy Carbomb in forum Traditional Kilt Wear
Last Post: 14th September 04, 08:23 PM
Last Post: 25th May 04, 10:02 AM
