29th July 07, 05:53 PM
hose for bigger calves
I am sure I have seen an answer to this question but I couldn't get the search wording right to find it. The kilt hose I currently have is very tight around my calves and is pretty hard to pull up. If I go with a size larger do you think it will bunch up? Or is there a brand that is better fitting for us gentlemen with the big legs?
EDIT!
SORRY! I just found the link to it.
Reason: because I am a dimwit
29th July 07, 05:57 PM
I think that Matt at the Scottish Tartan Museum might be able to help you I know he has traditional garter ties for ample calves, so I am sure he can help you out with hose:
http://giftshop.scottishtartans.org/hose.htm
29th July 07, 06:05 PM
Yep! I found it and ordered three pair green, black and navy.
31st July 07, 06:36 AM
The problem is not just calf size but also shape: Highly muscular calves (and legs) versus fat and flabby. With muscular legs, I think, one is in the self-coloured hose better off with standard issue. In diced and tartan hose there is a bit more pattern distortion but it'll always show with muscle flex unless the hose is really baggy and ill-fitting so really only an issue for standing at attention and where uniformity is central. Standard hose are made, I think, to 38 cm (15") and there is enough stretch. Just pull harder and after a while the hose will stretch and mold to your leg shape. Unless you are a body builder, climber or sprinter with calves much larger than 41-42 cm (beyond 16 1/2") I'd keep to the standard and its natural stretch and fit. If you are a colossus I'd look to made-to-measure as even the wide calf models won't fit correctly.
31st July 07, 07:46 AM
I started that other thread and still haven't convinced myself to pay the premium (although I am certain they are fabulous hose) for the really nice stuff.
That said, I ended up getting the $10 kilt hose (and a $20 colored hose) from USA kilts, and they fit great. I did end up getting the size L (11-14).
I am also stretching the other ones I had, but they are still very constricting.
[B]Barnett[/B] (House, no clan) -- Motto [i]Virescit Vulnere Virtus[/i] (Courage Flourishes at a Wound)
[B]Livingston(e)[/B] (Ancestral family allied with) -- Motto [i]Se je puis[/i] (If I can)
[B]Anderson[/B] (married into) -- Motto [i]Stand Sure
[/i][b]Frame[/b] Lanarkshire in the fifteenth century
[url="http://www.xmarksthescot.com/photoplog/index.php?u=3478"]escher-Photoplog[/url]
31st July 07, 08:11 AM
Another top choice for large calves is the Hamilton Dry Goods kilt hose.
http://www.hamiltondrygoods.com/sock.html
They have several colors in ribbed and cable knit.
Do a search here for hamilton dry goods or HDG and you'll find several threads about them (some with pics).
31st July 07, 08:19 AM
Ditto on the HDG hose. They fit my 20" calves with little trouble.
1st August 07, 06:25 AM
I think they must be a crap shoot, i ordered a set of 3 (grey) and I can get them on, but the elastic is stretched to its limit. I am pretty sure if I flexed they would snap.
1st August 07, 06:42 AM
I have heard one other member run into this, but my ribbed socks are great and the cable knit socks are even roomier though they are a little thinner. I believe the other member was able to exchange the socks for another pair.
1st August 07, 03:01 PM
Wow! That's large!! Like Arnold Schwarzenegger in form--- and even then there were rumors that he had implants.. Absolutely they won't fit into standard hose!
By escherblacksmith in forum How to Accessorize your Kilt
Last Post: 17th June 07, 06:48 AM
By ConfusedPollock in forum Kilt Advice
Last Post: 19th March 07, 11:23 AM
By Sindarius in forum Show us your pics
Last Post: 15th September 06, 05:14 PM
Last Post: 2nd December 05, 04:01 PM
Last Post: 15th September 05, 09:46 AM
