Results 1 to 10 of 35
Thread: Kilt ties
    18th December 06
    Burlington, Ontario, Canada
    Kilt ties
    I've never worn a tie with a kilt because when worn up above my navel the tie will hng over my kilt by several inches. What is the standard length of a kilt tie? Has any one ever modified a tie to suit?
    The tip of the front bit of your tie should be no lower than the top of your belt.If you are wearing a waistcoat the tie must not poke out from the bottom of your waistcoat.If you find your tie is too long,just re-tie the tie so the front bit is correct and just tuck the rest inside your shirt.
    18th December 06
    Are there no specific kilt cut ties?
    Panache is online now
    Grant,
    What works for me is to tie the tie so that front part of the tie is the proper length just above my belt (I always use a full windsor knot). The back part of the tie will be longer the front know so I simply fold it up along itself and then connect the three layers of material with a tie tack or a tie clip. In my experience the tie clip works better.
    Quote Originally Posted by ccga3359 View Post
    Not that I know of.The other thing to avoid are wide ties,they will make you look like Al Capone! Just a thought, Loch Carron make very nice solid colour ties that are nicely proportioned and I have no doubts that they would be be too long.
    And, take great care if buying a tartan tie from a highland games vendor. Some of them are made very short. Be sure to know the length you need for your body. Otherwise, about all they're good for is peeking out the top of a sweater.
    18th December 06
    This may be the ticket as I find regular ties just too long, even for Saxon clothing.
    1st March 04
    That is what I have always done, Jock. I have also tied my ties in a Windsor knot for as long as I can remember (but not quite back to when they were first invented!!), which uses up a little more tie than some other knots. On the other hand, I am/was (!) fairly tall and that must help.
    27th June 05
    London, Ontario, Canada
    Quote Originally Posted by Hamish View Post
    Ha, was Noah really grumpy?
    Okay, ties: note that in the UK ties are worn commonly by everybody (that's a universal general statement). Ties are so much rarer and special event here. Tucking the extra piece in, as recommended, is the standard practice.
    15th July 07
    California
    There is no need to shorten a regular tie to make it work with kilt!
    What you need to do is learn to tie the knot using more material.
    Go here: http://www.tie-a-tie.net/windsor.html and learn how to tie a windsor!
    That will use up enough length of a standard tie to make it work with a kilt!
  1. Knitted Hose Ties
    By cacunn in forum DIY Showroom
    Last Post: 25th September 07, 04:58 AM
  2. Ties fot SWKs and Sportkilts
    By campbell in forum Kilt Advice
    Last Post: 14th September 07, 09:12 AM
  3. Tartan Ties @ SWK
    By Tattoo Bradley in forum Miscellaneous Forum
    Last Post: 10th September 06, 10:38 AM
  4. Garter Ties
    By Southern Breeze in forum How to Accessorize your Kilt
    Last Post: 13th March 06, 01:07 AM
  5. Kilt Jackets and ties
    By David in Maryland in forum How to Accessorize your Kilt
    Last Post: 4th March 04, 07:19 PM
