Results 1 to 5 of 5
    RavenUSA
    How to taper an x-kilt to the waist??
    Hello! I'm making an x-kilt and was wondering it anyone knows how-to taper an x-kilt to the waist?
    29th January 06
    Asheville, NC
    Quote Originally Posted by RavenUSA View Post
    Alan H's instructions provide this information quite clearly. Doing the math is the trick, so calculate carefully and chalk carefully.
    Here's the link to the document you seek, grasshopper.
    http://www.xmarksthescot.com/forum/s...ghlight=x-kilt
    RavenUSA
    Thanks for pointing that out I missed that
    you'll be overlapping layers on the inside of the kilt, as you ascend from fell to waistline.
    The reason I didn't make the inner pleat edges actually meet (there's that fraction of an inch gap between the inner edges at the fell) was to minimize overlap at the waistline. If you really want deeper pleats, then you could make them that way, and live with the increased overlap at the waist.
    When making a box-pleated tartan kilt, you'll likely make the maximum pleat depth at the fell, and then overlap a fair bit as you go up.
    29th January 06
    Asheville, NC
    ...and since there is not so much fabric involved anyway, the overlapping at the waist is hardly noticeable. The original instructions do not include adding a lining, but that is covered in an addendum at the end of the document. I recommend it if there is broad overlap as this makes the inside of the waist area feel a bit less "bumpy".
  1. Fat Man and the Kilt at my Waist
    By obuchiteck in forum Kilt Advice
    Last Post: 14th July 07, 05:01 PM
  2. HELP! 44 waist kilt needed in MI
    By M. A. C. Newsome in forum General Kilt Talk
    Last Post: 23rd July 05, 01:10 PM
  3. Uk taper
    By dana in forum Contemporary Kilt Wear
    Last Post: 10th March 05, 07:41 AM
