Results 1 to 10 of 10
    16th July 06
    Sierra Vista, Arizona, USA
    Could Have Been a Sgian
    After jmercier and Panache showed off their sgian like knife building skills I thought I'd share this. In reality it could be a sgian.
    An Army friend of mine gave me a complete six point deer mount and an eight point shed for future sgian projects. He expressed interest in getting a knife and I offered him a choice of some blades I had lying around. He chose this one even though he could have gotten a sgian (it's deer season). I decided on moose scales, plain brass pins, no liners, and a decent finished size. He's got some big hands so I used a good size chunk of moose antler.
    The finished knife is 6.25", blade is 3.5"
    Here are the basic components. One old unknown blade with a great edge. Some bullwinkle and a couple of pins.
    Rough shaped with pins holding it all together. I taped the heck out of the blade because it was already very sharp. I have a piece of kevlar tape I put under the masking tape.
    Checking the fit to my hand. The new owner has even bigger mits.
    A finished useable knife.
    Finally, I made a heat molded plastic sheath that can accomodate a 2 inch belt. The finger hole holds it perfectly.
    The final finish is just 1000 grit then some grey rouge on a wheel. A spot of hand rubbed beeswax and buff.
    15th July 07
    California
    Kresent, do you epoxy and pin, or just pin alone?
    How do you hold everything together when you pound the pins?
    16th July 06
    I fit one scale, clamp and drill through the tang. Insert the pins on one side. Fit the other scale and clamp. Remove pins one at a time, drill and replace pins through both scales. With a friction fit I rough shape the handle. When I'm close all around I remove the scales and pin them together to true them up on the sharp end.
    I then epoxy the scales and pins in place. When the epoxy is set I do the final shape and poish. Depending on the material, I may use pins, cutler's pins (threaded), or just epoxy. As this is a knife that will see some heavy work I elected to pin it. On large full tang knives I always use cutler's pins.
    I have an aircraft rivet gun. I just filed these pins down and finished them with the the gun and a die. This isn't a required step. On smooth finished knives you smooth and polish everything.
    15th July 07
    California
    Thanks for the details.
    As always, you do great work. Hope to drop in some day.
    27th September 04
    Amelia County, Virginia, USA
    That blade looks like what they called a finger knife. I believe they were made by Gerber. They were great small knives for skinning. Yours looks much better than the original though.
    Jerry, Kilted Old Fart.
    Based its size it could be a sgian dubh.
    Nice work as always O'Neille. I have to get brave and try to make a knife with scales.
    10th May 06
    1000 Islands Area of Ontario
    Wow very nice work..is there anything you can't do??
    Sara
    ~Christopher Morley
    16th July 06
    Quote Originally Posted by Sheep In Wolf's Clothing View Post
    Sara
    Yes, I can't sit around doing nothing. Even when I'm doing nothing, I'm thinking about things to do.
    I may have to change my signature line.
    29th January 06
    Asheville, NC
    Quote Originally Posted by O'Neille View Post
    Boy, that's the story of my life!
    Great knife. Thanks for posting.
    Very nice work on it, it's quite an improvement.
  1. New Sgian dubh & Sgian Brew and a very public thanks
  2. My New Sgian
    By McMurdo in forum How to Accessorize your Kilt
    Last Post: 7th August 07, 03:49 AM
  3. Sgian (?) #3
    By Raptor in forum DIY Showroom
    Last Post: 9th May 07, 07:08 PM
  4. Sgian for a bet...
    Last Post: 27th April 07, 04:08 PM
  5. My new sgian
    By neo71665 in forum How to Accessorize your Kilt
    Last Post: 11th March 07, 01:41 PM
