Results 1 to 10 of 17
    14th March 06
    Military issue 182-96-108
    What do the numbers 182-96-108 on a label sewn on a military issue O.R. kilt signify?
    Thanks
    Last edited by macwilkin; 4th January 08 at 02:08 PM. Reason: oops! I hit edit instead of quote!
    11th November 07
    Ohio, USA
    I'm not sure...but my three guesses would be:
    1) Lot Numbers
    2) Serial Numbers
    3) Size (waist, length, hips)
    Good luck on finding out, though.
    Cheers.
    Clan Campbell ~ "Ne Obliviscaris"
    3rd August 07
    New York City
    If that's the size, I can only hope that it's in mm
    1st January 08
    Dundee, Scotland
    Quote Originally Posted by Galician View Post
    It's in cm
    Height-waist-seat.
    28th March 07
    Iowa
    The first number is the height of the wearer's height, in centimeters, the second number is the waist, in centimeters, the third number is the hip, also in centimeters.
    I see I wasn't fast enough
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    Quote Originally Posted by gilmore View Post
    Thanks
    What else does the label say?
    T.
    11th November 07
    Ohio, USA
    Cool...I knew someone would know.
    14th March 06
    Quote Originally Posted by graham_s View Post
    It's in cm
    Height-waist-seat.
    Thanks for the prompt answer
    1st January 08
    Dundee, Scotland
    I spent 15 years in the UK Military.
    I've seen the size format before
    15th July 07
    California
    Thanks
    You are all wrong!
    This is an ancient tally system used to pass on critical data from one kilt wearer to the next kilt wearer.
    The three number groups indicate the cumulative number of times that, while wearing that kilt, the wearer was asked the following.
    Number group one - What’s under the kilt?
    Number group two – Where’s your bagpipes?
    Number group three – Aren’t you cold?
    182-96-108 is a rather low number and indicates that the kilt in question was not worn very often and should have plenty of wear left. I have one rather old kilt, which has a current register of 6823-2933-733. I should mention that I live in a warm climate.
    By use of this number, you are able to gage the amount of wear left in a kilt. Most well made kilts will last until each group of numbers is well into six digits.
    I hope this clears it up for you. It’s always nice to help out the newly kilted.
  1. A moral issue
    By Streetcar in forum Miscellaneous Forum
    Last Post: 25th August 07, 08:46 PM
  2. Jacket issue
    By Chaplain Harris in forum Kilt Advice
    Last Post: 16th March 07, 01:58 PM
  3. Nato Issue Kilt
    By chacbalam in forum General Kilt Talk
    Last Post: 20th December 06, 08:57 AM
  4. Signing in Issue
    By Colin in forum Comments and Suggestions
    Last Post: 9th May 05, 06:36 PM
