Results 1 to 10 of 23
    A few thoughts on pleating to the stripe
    I just finished a kilt pleated to the stripe in the Royal Naval Association tartan, and I thought I'd post a couple of pics that illustrate a few things about pleating to the stripe.
    This tartan has a huge sett (something like 13"). While it looks at casual glance that the tartan ought to repeat every red/white/red stripe, the intervening blocks are not identical. In reality, this is an ABAC sett, and the sett has to include the full tartan repeat.
    If you tried to pleat this to the sett, you'd only get about 14-15 pleats into the back of the kilt (and each pleat would be about 6" deep). There are two alternatives. You could try "cheating" the pleats by picking up the right tartan elements at intervals of less than one full sett. This would probably work for this tartan, because most of the elements you'd want to pick up occur more than once per sett. You might have to have an occasional full-sett pleat that would be deeper than all the rest, but that wouldn't show except from the back side of the kilt.
    The other alternative is to pleat to the "A" stripe that occurs twice per sett. That's what I did in this case. This also makes the pleat reveal and the pleat interior very different in color, so that the pleats have a cool flash of dark when the wearer walks.
    You can also see why it's really really important to stand back from a test pleating to get the overall color effect. Even though this kilt has no purple in it, the back of the kilt from a distance has a purple cast to it because of the way the red, black and royal interact. You can see the same thing in Black Stewart kilts pleated to the stripe. I like it, and so did the customer, but you don't want to be surprised by failing to check!
    And one last thing. I actually had enough tartan to put two more pleats into this kilt. I chose not to, because that would have made each pleat small enough at the waist that the narrow black stripes edging each pleat would have essentially vanished at the waist, putting the red stripe of one pleat against the red stripe of the next. That wouldn't have looked good. So, it always pays to do a test pleating _with the pleat taper_ to make sure that you don't lose an element that is crucial to the overall appearance of the kilt.
    15th July 07
    California
    As only a kilt wearer and not a kilt maker, I always enjoy your explanations. Even with having your book and being able to look at it I still learn things from your posts.
    I really like pleating to stripe and that is my preferred way.
    And before I say anything else, or perhaps instead of saying anything else.
    That is one georgeous kilt!
    Nice work Barb!
    3rd November 07
    KY
    Thanks for the insight.
    18th December 06
    Burlington, Ontario, Canada
    Just curious could you pleat it to alternate BC stripes? I'm not asking you to take the pleats out to show me as I know who this kilt is for and that would just be mean. Can't wait to see it in person.
    Quote Originally Posted by ccga3359 View Post
    Matt does this for box pleated kilts, and it makes a lot of sense for certain tartans for that kind of kilt.
    I've seen trad knife-pleated kilts kilts on occasion that are pleated to alternate stripes, but it's my impression that it's not considered "proper" for a knife-pleated kilt. If someone knows differently, I'd be happy to be educated!
    13th March 05
    Barb, I don't know if this is what you mean, but the Royal Scots and The Canadian Scottish Regiment wear their Hunting Stewart pleated to alternate red and yellow stripes.
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    Whether or not a kilt can be successfully pleated to alternate stripes (whether it's a four yard box pleated kilt, or an eight yard knife pleated kilt), will depend upon the sett size.
    When you pleat to alternate stripes, you are effectively treating the sett as if it were either a) half the actual sett size, which works well when dealing with exceptionally large tartans, or b) one and a half the actual sett size, which works well when dealing with tartans with a small repeat.
    The Hunting Stewart tartan, which has a relatively large repeat, is customarily pleated to alternate stripes (yellow and red) when pleated to the stripe. As far as civilian tartans go, I've seen full eight yard kilts pleated to alternate stripes once or twice. It's certainly not common, but it can be done, so long as the size of the tartan allows for it.
    M
    10th May 06
    1000 Islands Area of Ontario
    Wow what a lovely kilt. I love kilts pleated to the stripe, most of the kilts I own (or make) are pleated this way. Thank you Barb for the wonderful tutorial!!
    Sara
    ~Christopher Morley
    M
    Thanks, Matt! I'm glad to know this. You are THE BEST!
    8th February 04
    snip...
    The Hunting Stewart tartan, which has a relatively large repeat, is customarily pleated to alternate stripes (yellow and red) when pleated to the stripe....
    I think we'd call that the ketchup (or catsup) and mustard stripes.
  1. Pleating challenges #1: dealing with a too-wide central stripe
    Last Post: 12th December 07, 03:11 PM
  2. Pleating to the stripe or stripes.
    By wingedferret in forum General Kilt Talk
    Last Post: 2nd October 07, 03:38 PM
  3. An interesting example of pleating to stripe
    By Barb T in forum Show us your pics
    Last Post: 16th July 07, 01:25 PM
  4. Pleating to set and stripe
    By Freelander Sporrano in forum Kilt Advice
    Last Post: 30th August 04, 05:50 PM
