16th June 08, 11:20 PM
Kilt Pockets
Someone sent me an e-mail asking to share my idea/pattern for the pockets, so I am going to try my best to explain this and show a some with pictures along the way. A few things to keep in mind, the distance from my waist to my hips is 5", this is also where I gathered/darted the pleats together. I used a simple cotton muslin for pocket material. I cut 4 of them 7" wide x 15" long. Once I figured which pleats I was going to tuck them in and hide them I measured from the waist mark down 5" and then an other 5" for the pocket opening and did not sew my down that inside pleat.
These pictures are of the inside/wrong side of the kilt
I cut a slit in the kilt from the two marks along what would become the pleated edge. I placed one piece of the muslin on each side of the slit on the outside/right side of the kilt and sewed the pieces to the kilt along the slit on both edges.
I then turned the muslin pieces to the inside of the kilt and sewed the pieces along the slit on the outside/right side of the kilt across the bottom up the other side of the slit and across top to give the pocket a finished sewn look and to make it a little more sturdy.
I then sewed the inside pleat of the pleat that the pocket is attached to including the muslin.
Sorry no picture here.
On the inside of the kilt, I laid the two pieces together and sewed the edges together to form the pocket.
To close off the top of the pocket and to keep the pocket supported I sewed the top of it when I sewed the waist band around the entire kilt
I hope this clears things up. If not, I will try to clarify more.
17th June 08, 01:27 AM
Good clearification.
17th June 08, 03:41 AM
That's a very good explanation and the it seems fairly simply. THanks for posting that information.
Jake
17th June 08, 06:10 AM
I always wondered how the hidden pockets on a kilt were done, this explains a lot. Thank you.
17th June 08, 06:44 AM
Thanks a ton.
I want to work these in with the next kilt I make. Thanks a bunch.
~Yeti
17th June 08, 09:41 AM
Excellent. I think I will risk one of my lesser kilts and try a retrofit.
17th June 08, 11:10 AM
How do you finish off the outside?
17th June 08, 11:30 AM
Thanks for posting that. Good little tutorial.
17th June 08, 05:42 PM
Here is a close up shot of the pocket. After I sewed the muslin to the outside/right side of the kilt, I then folded the muslin back to the inside of the kilt, I stitched the kilt material and the muslin together with the kilt on top.
I hope this clears up your question.
17th June 08, 06:30 PM
hmmmm, that looks nicer and easier than the way I had been doing pockets.
I like the way I came up with to cut a slant in the one pleat like the UK kilts, but it is a pain in the butt to do and I haven't figured out a way to make it really clean yet.
Still working on it.
In the mean time, that is a much cleaner pocket than the last one I did.
I will have to incorporate it into my X-Kilt that I am finally gonna get built this weekend.
By O'Neille in forum General Kilt Talk
Last Post: 27th August 06, 05:48 PM
By Southern Breeze in forum Kilt Advice
Last Post: 10th March 06, 07:00 AM
By dejudicibus in forum General Kilt Talk
Last Post: 29th December 05, 03:21 PM
By Casey in forum How to Accessorize your Kilt
Last Post: 9th June 04, 03:04 AM
