Results 1 to 10 of 21
    16th May 08
    forgotten
    Poly/Rayon fabric at Joann Fabrics
    I was walking through Joann Fabrics at lunch today. As I was looking around I notice 8-10 bolts for plaid material. What I saw caught my eye, but I figured it was just some of their cotton flannel. My surprise when I looked at the end of the bolt was that it was a polyester rayon blend. I understand the rayon is call viscus(sp) in the UK. I also found a coupon for 40% off. At $7.99 a yard original cost, I walked out with what I consider a nice looking fashion tartan for $3.30 a yard. I got all 7.75 yards and now have to plan how to pleat the tartan for a kilt.
    Moderator - I understand that this is a region/country specific post and will understand if it is deleted.
    8th May 08
    Jacksonville, FL
    You 'ought to post pictures.
    3rd November 07
    KY
    Did the same myself today. Got a black and blue houndstooth for a tank attempt and a ivy cap (if I ever get a pattern)
    31st May 08
    dc
    Quote Originally Posted by Friday View Post
    I did the same yesterday at JoAnns. I even posted the picture of the tartan for help with ID. One of them is very similar to Stewart Grey. Did you find that these some of these polyviscose are too lightweight? Hmmmm. we'll see. Let me know how yours turns out.
    16th May 08
    forgotten
    Quote Originally Posted by meinfs View Post
    Some were light, the material I got was a medium weight similar to some material I have already used and liked. It will be a while before I make it into a kilt, I have too many things in the fire at this point.
    I was thinking about a reverse Kingussie, but I have to think about this.
    For the perfect reverse Kinguisse kilt the pattern should be reversible - so if the left side has stripes (for instance) of red blue white, you can make the right side stripes run white blue red, so that if you pleat to the red, then the blue is behind it and the white shows when the pleat is opened up.
    Don't worry if you can't make the pattern work that way - it is just a thought for the perfect RevK kilt.
    Baroness Anne the mirthful of Fritterton on the Heath
    16th May 08
    forgotten
    Meinfs got some of the same fabric and posted this picture:
    What I have is the fabric on the left. I have not decided how to pleat it yet. what come to mind is a pleat where the red strip is hidden and flashes when you walk. I'm not sure if or how to do this until I spread it out and play.
    19th May 08
    Oceanside CA
    That sounds yummy. Pleat to the right-hand thin black/yellow/white vertical would be my first guess. If you have a scanner, fold some up and scan it in different configurations, lets you look at various pictures to decide (and I think colors stay more true in scanning than in photo, but that's just my own opinion/experience).
    I'll be at Joanne's next week. . . for drapery materials. . . but that red/gray is tempting. . .
    9th February 07
    Hillsboro, OR USA
    I personally have only found very lightweight material at Joann's. Sounds like it's time to go back and look again.
    16th August 06
    Salt Lake City, UT
    I can verify that the polyviscose materials are available in the Salt Lake Joann's. I picked up some Royal Stewart. They also had Stewart Black, and Blackwatch. It appears to be about 11 oz or maybe just a bit lighter. In my opinion it should be ok to make a kilt with since I have done this sort of lightweight stuff before. A liner in the apron may or may not be necessary, we'll see. It's 45 inches so you will not be able to split it.
    It's a good deal for someone who just wants to practice, or wants a knock around kilt though.
    Good hunting!
  1. Non-Tartan Fabrics
    By AlphaKilts in forum Professional Kiltmakers Hints and Tips
    Last Post: 18th October 07, 04:22 PM
  2. Denver Fabrics
    By Erisianmonkey in forum DIY Showroom
    Last Post: 16th October 07, 07:37 AM
  3. Poly Viscose vs acryllic fabric question
    By Sean_the_Kilted in forum Kilt Advice
    Last Post: 11th June 07, 09:36 AM
  4. Fabrics, etc
    By toadinakilt in forum Professional Kiltmakers Hints and Tips
    Last Post: 28th February 06, 10:47 AM
  5. Cotton Poly Vs. Poly Vis
    By Atticus in forum Contemporary Kilt Wear
    Last Post: 30th August 04, 07:19 PM
