Results 1 to 5 of 5
    14th May 08
    Slovenia
    Tie and bow tie pattern
    I'm looking the tartan ties and all have pattern set diagonaly. Bow ties can be seen with pattern running straight.
    Would it be wrong to have a tie with tartan set straight and with prominent stripe in the middle (like on apron)?
    3rd November 07
    KY
    Up to you really. To be honest, I'm surprised I haven't seen it more as it takes less fabric that way.
    14th May 08
    Slovenia
    Quote Originally Posted by OFCJAX View Post
    That's the reason way I'm asking. With some tartan leftovers from kilt maybe I could do something, if I can make it stait and centerd on stripe.
    Harold Cannon's Avatar
    Harold Cannon is offline Oops, it seems this member needs to update their email address
    15th April 08
    Alabama
    Tie On a Diagonal
    The reason that most ties ( not just tartan ties ) are on the diagonal is that when tied it will lay flat against the chest. Ties cut straight seem to curl and twist. This I discovered after making a few of my own.
    17th July 08
    Fayetteville, NC
    Quote Originally Posted by Harold Cannon View Post
    That is precisely why all ties are cut on the bias. There needs to be a bit of stretch to the fabric to keep them from curling (four-in-hand) and to stay tied! (bow tie) If you cut the strips carefully, you can join shorter ones to make the longer strip that is needed, and unless one gets the nose against the tie, would never be able to spot it.
  1. Could I get a pattern?
    By NorCalPiper in forum General Kilt Talk
    Last Post: 16th February 08, 06:27 PM
  2. Trews pattern
    By Machinest in forum Professional Kiltmakers Hints and Tips
    Last Post: 24th October 06, 05:21 AM
  3. Necktie Pattern?
    By Kilted Taper in forum How to Accessorize your Kilt
    Last Post: 28th June 06, 05:51 AM
  4. Got Pattern?
    By JayFilomena in forum Professional Kiltmakers Hints and Tips
    Last Post: 2nd January 06, 09:06 AM
  5. Pattern
    By toadinakilt in forum Professional Kiltmakers Hints and Tips
    Last Post: 20th September 05, 04:24 PM
