Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    5th August 07
    I just had a thought about making a kilt
    I see that buying tartan is quite expensive. So, I was thinking about buying a Stillwater kilt, taking it apart and using the material to make my own kilts (box pleats, stabilizer, interfacing, lining, removing the third strap, etc). This seems like it would be easy since SWK's don't have the pleat material cut out of the fell. This would yield box pleated kilts in actual tartan patterns, though in 11 ounce acrylic.
    What say the rabble?
    14th December 05
    Coeur d Alene, ID
    Now, I could be wrong but I think Alan actually purchased some acrylic tartan yardage from Frugal Corner. Its a fuzzy Friday memory so don't hold your breath I'm probably all wet.
    Quote Originally Posted by pdcorlis View Post
    It's Friday, but PD Corlis is correct. I purchased a couple of yards of their "13 ounce" material in the Clark/Clergy tartan and made a liturgical sash for one of our pastors.
    I would STRONGLY STRONGLY recommend that if you purchase material from the Frugal Corner with intent to make a kilt, that you buy their "16 ounce"...and make note of the fact that I have put those fabric weights in "quotes".
    5th August 07
    Thank you very much for the advice, I got it
    Ardchoille,
    When you do get the fabric find a good scale and weight it.
    I'm sure others would like to know the actual weight of the Acrylic fabric.
    5th August 07
    Ardchoille,
    Will do. When it says "16 ounce" is that 16 ounces per yard?
    15th April 07
    State College, PA
    16 oz per yard of 60" wide material. About a pound a yard.
    Wallace Catanach, Kiltmaker
    22nd November 07
    US
    ardchoille, the StillWater's are made from aprox. 6 Oz acrylic fabric.
    I have no comment on the FC material.
    When I first read your post, I thought you were talking about the wool heavyweights. Those might be worth fooling around with if you have the kilt making skills. I can't really say anything about what would or would not make a good box pleat kilt. That's for kiltmakers to tell you not to do.
    7th July 06
    Roswell, Georgia USA
    Unless you get one of the wool kilts. they are closer to 13 oz.
    One yard long X 60" wide = 1 fabric yard.
    There are 2160 Sq. inches in a fabric yard.
    1) Weigh your total piece of fabric. Down to the ounce if you can.
    2) Then measure the entire length of the fabric in inches. Then measure the width in inches.
    3) Multiply the length by the width. This will give you the total sq. inches of fabric that you have.
    4) Then divide by 2160. This will give you the amount of fabric you have in fabric yards.
    5) Divide the weight in oz. by the fabric yards and you get the ounces per yard.
  1. Under the Kilt, Just When You Thought You Heard It All!
    By Jim Sloan in forum General Kilt Talk
    Last Post: 2nd June 08, 03:11 PM
  2. Kilt making?
    By singforsam in forum Professional Kiltmakers Hints and Tips
    Last Post: 2nd April 08, 09:54 PM
  3. Thought it was a kilt
    By davedove in forum General Kilt Talk
    Last Post: 12th September 05, 10:42 AM
  4. Kilt, me? I thought it would never happen!
    By Jewddha in forum General Kilt Talk
    Last Post: 30th April 05, 10:07 PM
