Results 1 to 3 of 3
    Fringing a fly plaid
    Here's how to make the kind of fancy purled fringe on the edge of a fly plaid like the one shown on the following site:
    http://www.lindaclifford.com/FlyPlaid.html
    I asked my mom, who knows everything, and here's what she said. Thought I'd share it with you folks in case you wanted to make your own:
    Start by pulling threads out of the edge of the tartan until you have maybe 3-4" of fringe all the way around. You can experiment with the length you want - the twisted and tied fringe will be shorter than it is when it's not yet tied. Just remember that you can't put the threads back, but you _can_ take more out!!.
    Select 4-8 warp ends (depending on the weight of the yarn) For the kilt fabric, I think that 6 would be about right. Anyway try 6 and see how it works. Divide the six into 2 equal groups. Twist one group of 3 to the right until it kinks. Holding on to the end of that, twist the other three to the right until it kinks. Hold both together at the tip and twist them to the left until the whole group of 6 kinks. Tie a tight overhand knot in the end. It is easiest if you use some kind of "board" that you can stick pins into. Stick the pin into the fabric and into the board at the point where the fabric ends and where the fringe begins. That gives you something to brace the fringe against while you are doing the twisting.
    Barb
    17th July 08
    Fayetteville, NC
    I fringed and purled a fly play during the 14 weeks of therapy following cancer surgery. . . kept me from going stark staring bonkers! I used a spring clothes pin to hold the first twisted strand, worked fine, as the pin has enough weight to keep it from untwisting.
    Following "Scotty" Thompson's advice in So You Are Going to Wear the Kilt I did not mix more than two colours in any one fringe piece.
    Very time consuming, but the end result is most impressive.
    Thanks, Barb. I recentily trimmed down a belted plaid, so now I know how to fringe the cut end.
  1. Fringing a fly plaid
    By Barb T in forum How to Accessorize your Kilt
    Last Post: 13th January 09, 08:53 PM
  2. Fly Plaid
    By Ancienne Alliance in forum Miscellaneous Forum
    Last Post: 16th July 08, 03:44 PM
  3. What is a fly plaid?
    By ardchoille in forum How to Accessorize your Kilt
    Last Post: 22nd April 08, 12:41 PM
  4. Shoulder plaid(e)/ Day plaid(e)
    By Dutchomatic in forum Kilt Advice
    Last Post: 12th January 08, 09:36 PM
  5. Tie with a fly plaid?
    By Nighthawk in forum Kilt Advice
    Last Post: 25th December 07, 02:05 AM
