Results 1 to 10 of 12
Thread: Critique
    16th July 08
    England
    Critique
    So, #1 is done and after two night's dancing (one night Contra, the other Modern Jive, both energetic) it hasn't fallen to pieces and I feel a little happier that it won't.
    My thought now turn to #2 and what I can do better knowing now how it's done.
    One thing I did think about when I was sewing away and that concerns the canvas and lining. Is it necessary to use a straight piece each time and shape it?
    I have loads of canvas and lining and it occurred to me that I could cut a slightly curved piece matching the curve on the kilt and save myself the trouble shaping.
    So, Master Kiltmakers and anyone who can make kilt, would a curved piece of canvas/lining work as well?
    Tetley
    The Traveller
    What a wonderful world it is that has girls in it. - Lazarus Long
    First I have to confess to not making structured kilts, but I know how to, and to do lots of other sewing too.
    The whole raison d'etre for the internal reinforcement is for it to be shaped to the body beneath and provide a foundation for the external layers.
    The rigidity of the material is why it was chosen, so moving the shaping to the edges is not going to provide the three dimensional adaption to the curves of your anatomy - not unless you are rather unlucky.
    Do a Grant - rejoice in you rear (this will be understood if you have delved into the 'Off Topic' section) and put in the shaping within the canvas as required to round out the reinforcing layers.
    Anne the Pleater
    15th April 07
    State College, PA
    The canvas is there to support the tightening of the belts. The cavase is placed to relieve the stress on the pleats. It you use a bias piece of canvase, it will stretch and the stress will go thru the pleats, loosing the stitches and causing unsightly stitches to show, stretch, and break.
    Maybe you could use a piece of leather because it has no bias and will shape to the curves of the back.
    Wallace Catanach, Kiltmaker
    16th January 06
    London
    I'd be very cautious about using leather inside a kilt lining, however lovely the feel, the smell... it's not really great when it's ironed... or washed.... and if wet the dye from many leathers do migrate...
    One of the main reasons for using a straight piece of hair canvas and pleating it across the back is to give the kilt stiffness parallel to the pleats but allow it flexibility across the pleats. This keeps the kilt from buckling and developing unsightly horizontal rolls in the fell when you're wearing it. You would do this even if the kilt didn't need shaping because the waist and hips were the same measurement. Even in a kilt like that, you'd make the pleats in the canvas.
    The lining is structurally less critical, but it's a load easier to stitch both the bottom and top of the lining edges parallel to the grain of the fabric, and it looks better, too.
    16th July 08
    England
    Now that makes a lot of sense and I can see the reason for doing it. Thanks again Barb.
    Tetley
    The Traveller
    19th May 08
    Oceanside CA
    Perhaps this question should be a separate thread, but I'll chime in here with a "why do it this way?" question I encountered after sewing the MacWerner Watch per The Book's instructions.
    When joining two lengths of tartan, you're told to create a flat-fell seam that lies midway between the inner and outer crease of a pleat. The seam extends from hem upward to the point where the excess material is later cut away. During final pressing, I found that this seam created a slight bulge in the pleat from fell to cut-away.
    On a previous hand-sewn wool kilt (done to other instructions) I had placed the join right at the inner crease of a pleat. This leaves raw edges inside the kilt, but I did a hand-overcast stitch which has kept them neat. Granted, when you start tapering that pleat the join will no longer be right at the crease -- but it doesn't create the bulge that the flat-fell does.
    Pros and cons for each method, but am I missing some other rationale for using Barb's method vs. "mine"?
    I've seen it done this way on other kilts, and it's perfectly OK if you don't mind the raw edge. Personally, I don't like the look of the raw edge, and I've made literally hundreds of kilts and have never had the join make a bulge when I've pressed the kilt. And it hasn't mattered whether I'm making an 11 oz kilt or a 16 oz kilt, or even a 4 yard box pleated kilt (which has less fabric between the outside layer and the join).
    So, I'm wondering. Are you folding it over twice when stitch the join instead of just once once? I'm perplexed about why your seam has a bulge.
    19th May 08
    Oceanside CA
    I think I did it as instructed (but memory doesn't always serve). Stitch seam, trim one allowance to 1/4", trim the other to 1/2", fold the 1/2" over the 1/4" and stitch along the fold. This results in three layers of fabric next to the seam.
    Perhaps it should be only two layers? If I trim one allowance to 1/8 and the other to 3/8, so the two raw edges meet instead of overlapping but are both still encased and captured by the stitching.
    The flat-fell finish is certainly nicer than the overcast raw edges, if I can get it right!
    Sounds right - it makes 3 thicknesses right at the seam. What weight tartan were you working with?
  1. PC critique wanted
    By Kilted KT in forum Show us your pics
    Last Post: 24th October 06, 09:50 PM
  2. Please critique the outfit
    By turpin in forum Kilt Advice
    Last Post: 16th August 06, 01:12 PM
