Results 1 to 10 of 13
Thread: selvedge?
    4th October 07
    Charlotte, NC
    selvedge?
    i recently got material from ebay and one end is completely...undone(unselvedged?? is the best word to describe. could i take this to a local seamstress to fix this or would i actually have to take this to a kiltmaker?
    Gillmore of Clan Morrison
    17th July 08
    Fayetteville, NC
    The selvedge is the finished edge along the length (warp) of the fabric. If you mean the cut end is fringed out, then there is no real problem. If it is totally along one long side, then either a seamstress or a kilt-maker could either bind the edge or put in a hem. Without seeing what the problem is, I really can't help you beyond this.
    8th February 04
    Pics?
    If the fabric is 'single width (about 28 or 32" wide), then most likely only 1 edge will be finished with a proper kilting selvedge edge. If it's DOUBLE WIDTH cloth (i.e. 54 to 60" wide), then BOTH edges should be finished. If not, sounds like you'll have to hem it.
    4th October 07
    Charlotte, NC
    first is a selvadged end, second and third are pics are the unselvedged ends.
    hope this helps
    8th February 04
    Looks like 1 kilting selvedge edge and 1 with a 'CUT EDGE'. How wide is the fabric?
    If you bought a kilt length of fabric it will be one half of the standard width of material, that is 27 inches of the 54 inch width, so you have one continuous piece to make into a kilt.
    Most people wear a kilt which is about 24 inches long, so there is enough fabric to cut off a narrow strip from the upper edge, sew in the pleats and then bind the raw top edge with a piece from the upper edge.
    In times past the material would most likely be woven on a narrow loom, and there would be a selvage at both top and bottom and no need to make a waistband to keep the edge neat.
    What are your plans for this fabric?
    Anne the Pleater
    4th October 07
    Charlotte, NC
    its a 55", so its double wide. turns out both ends are cut end...
    my plans is to make this into a great kilt.
    OK, I'm still confused. Do you mean that your have a piece of fabric that has one long selvedge edge and one long cut edge? Then the two short ends are also cut?
    Or is this two long selvedged edges and two short cut ends?
    4th October 07
    Charlotte, NC
    yeah, sorry, both ends, the 55" sides, are cut. the length edges are fine, its the width edges that are cut.
    i hope i'm making better sense.
    14th August 07
    Halifax, NS
    Ok. So, totally normal then. Nothing that needs 'fixing'. This is the way fabric is when bought.
    The cut ends are where the fabric has been cut from the bolt. Just imagine a roll of toilet paper. Your fabric comes on a roll (or bolt). The 55" ends are the ends of 'sheets'.
    You'll need to either hem it or bind the edges.
  1. Semi-Trads without a fringed selvedge
    By Gunnar in forum USA Kilts
    Last Post: 28th September 08, 06:37 AM
  2. what is tuck in selvedge?
    By zeeew in forum Kilt Advice
    Last Post: 27th July 08, 12:48 PM
  3. X marks Damaged Selvedge
    By Moosedog in forum DIY Showroom
    Last Post: 1st November 07, 07:27 PM
  4. LOOK at the SELVEDGE!!!
    By MacWage in forum General Kilt Talk
    Last Post: 20th July 07, 09:21 AM
  5. selvedge
    By Moosehead in forum General Kilt Talk
    Last Post: 8th February 06, 06:06 PM
