Results 1 to 10 of 11
    8th July 08
    Middle Grove, NY. Just outside Saratoga Springs.
    i know I'm going to regret asking this...
    .....I just know I am. Nothing good can come of it. OK...so I'm having a kilt problem. When I wear a trad kilt, and take a seat someplace, I've noticed that no matter how well I do a "pleat sweep" to get things under me, I end up with certain...ahem...aspects of the naughty bits in contact with the seat. I especially notice this if I am sitting up to a restaraunt table, or at a barstool. Now I know this is not good form on sooooo many levels , and not that comfortable either, but I'm at a loss. I wear a 23-24" long kilt at 5'11", I'm hitting the mid knee, and I don't have a gigantic keister or anything (45" hips) , sucking up the posterior coverage but it happens consistently. Not a problem with contemporary casual kilts, worn at the pants waist.
    Any of you more experienced kilt wearers experience this, or come up with a solution? (besides the anatomically correct barstool...that was a riot!)
    2nd July 06
    Madison, Wisconsin
    I don't really have that problem, but if it really bothers you, you could always wear underwear.
    5th September 05
    Chicago
    Yeah, it's not been a problem for me and it sounds like we're approximately the same size...you are doing a discreet sweeping of the kilt as you're sitting?
    Like Beloitpiper said, underwear is always an option...no one can fault you for maybe wearing a pair of black boxers or boxer briefs if it's a problem.
    Best
    AA
    8th July 08
    I'm definately doing sweeping as I sit. I've considered going to boxers, but would rather solve the problem as I enjoy the comfort of going regimental.
    Southern Breeze's Avatar
    28th August 05
    Chatsworth Georgia, USA
    Joining a Nudist colony would help with the pleat sweep problem.
    Have you seen Hamish's pleat sweep video?
    http://www.xmarksthescot.com/forum/v...x.html?t=20913
    2nd July 06
    Madison, Wisconsin
    I've been thinking about it, and sometimes I notice that when people pull their kilt down to their knees, they only pull the front down. Next time, make sure the pleats hit the knee at the same level as the apron.
    8th July 08
    Quote Originally Posted by Southern Breeze View Post
    No I haven't, and one of our esteemed female members pm'd me with what I think is my problem! Not enough "hip-flick" and bending over too much to sweep the pleats, causing the rear hem to rise too much in the process. I'm so glad there are women on this board! I'll have to watch Hamish's video when I get home. I don't think my system will play it at work.
    nope...requires Flashplayer and my work 'puter is without.
    Her other observations included:
    I just watched Hamish's video again, too. Some of the big things I noticed (ignoring the pleat sweep for a moment):
    - Keep the rear down, don't stick it out to sit, or bend over while trying to sit or reaching back to do a pleat sweep. This will cause the kilt to hang vertically and get crushed accordian-style. You'll have very little kilt under you.
    - Lower yourself to the edge of the seat and while you continue lowering yourself to sit, THEN push your body back. This seems to help pull the pleats where they need to be, under your rear and legs.
    Sometimes, I wonder if the "angle" of the pelvis and direction of sitting are the biggest problems for making sure you have the kilt under you when you sit
    Thanks, all, again for the help! Now I have to go home and get a kilt on...
    5th September 05
    Chicago
    Quote Originally Posted by csbdr View Post
    Then I would definitely stay away from metal park benches in the Winter if I were you.
    If you think that getting your tongue stuck to a frozen flagpole is a bummer...
    Best
    AA
    22nd November 07
    US
    Dude, sit your rump down on the edge of the seat and slide back on to it; there won't be a problem.
    Although, I think you've realized that; looking at one of the posts back there.
    29th December 07
    KENT WAQ
    I AGREE. I had that same "problem, at first, esp with my Heavy WT 8 yd. Kilts. I ended up asking a my daughter (who has done "some modeling), wears skirts (mid knee to knee length ) for help. The 1st thing she saw was that when I sat, I bent forward & put my BUTT into the seat, then sat up & leand back into the seat causing my rear to "slide forward.
    I have learned to do a full sweep, stand straight, with legs TOGETHER, then sit down STRAIGHT with the edge of the seat as far forward on my thighs as I can get it (I am 6' with fairly long legs) Then before I "lean back, I "scoot" my BUTT back as far as I can. IT WORKS FOR ME!!
    NOTE- the hard one to "master" is BAR STOOLS. Even for me they are "HIGH", but with "practice" they can be "conquered"
    Puffer
