Results 1 to 10 of 18
    20th March 07
    NYC AREA
    Advice from pipers
    I am starting to finally move from my chanter to the pipes, but I have a question about the canter reed. What is the fastest way to brake a new reed in. I am having a hell of a time keeping the pipes sounding, and I don't know if the reed is to hard, or just needs to be broke in.
    15th January 09
    Boulder, CO USA
    Ask your instructor! You do have an instructor, right?
    You can gently shave it down (evenly on both sides) or you can play it and play it and play it until it's nice and broken in and you're stamina is good enough to play it.
    For a total newbie, I'd suggest shaving it (your instructor should help, at least the first time).
    2nd July 06
    Madison, Wisconsin
    What strength and maker is it? I'd say don't touch it. It's not easy when you first get on the full pipes. Really, it just takes time to break it in. If you're still having issues after a few months, then shave or chisel it, but I'm afraid you're just going to have to bear it.
    13th March 05
    Quote Originally Posted by beloitpiper View Post
    I'd add that another way to get the chanter going when you're first on the full pipes is to cork the drones. Then, as your strength and technique grow, you can uncork one by one and then, voila!
    22nd January 07
    Morganton, North Carolina
    I've had good luck ordering Duncan Soutar "easy" reeds. Some (Shepherds) seem to be harder than others. You also need to make sure that you don't have leaks in your bag, tuning slides, etc. What brand of pipes do you play?
    As some of the other folks have mentioned, though, if you're having this issue you should talk to your teacher. If you're "going it alone" you run a real risk of learning how to be a very poor piper and having headache after headache on some of the simplest things. Not trying to be negative here, just trying to share some hard-won experience.
    Cordially,
    David
    23rd December 08
    Phoenix, Arizona
    Chanter reed
    If you've got an instructor ask. If not, try Chris Apps. He has a very informative web site on reeds which includes a nice little video on shaving a chanter reed. You might also consider ordering a reed from Chris. He will custom build one for you which will use as little as 18lbs pressure (VERY easy). Cost about $18 US.
    8th May 08
    Jacksonville, FL
    Don't play a reed that it too hard. That's how I got a hernia. I'm 23 and on the mend... and the worst part was that I couldn't play on St. Patrick's day. I've been playing for over 5, almost 6 years. I was playing a medium-hard warnock reed and towards the end of the night I started having some pain that turned into having A LOT of pain in "the effected area."
    10th March 05
    Fergus Ontario, Canada
    well my instructor told me not to touch the reeds play till you get used to it , I did the same thing MAcman suggested i cork my pipes and slowly uncorked each drone as my strength and skill increased, I use elliot reeds in the medium strength they brake it nicely. Do not shave the blades of your reed you lose tone .
    MacHummel
    10th January 09
    Oconomowoc, WI
    Fill me in here guys... are these "double reeds, like an Oboe or Bassoon?.
    I played Clarinet, Bass and Contrabass Clarinet and Alto Sax for years, and it was common practice to "Condition" your reeds, by shaving, sanding and burnishing them to close off the pours as needed. Are Pipe Reeds really that different?
    2nd July 06
    Madison, Wisconsin
    The chanter reed is a double reed like an oboe. The drone reeds are all single reeds. I never shave mine, but have chiseled some in emergency situations. Now, I always buy two reeds at a time and break them in at the same time so I can have a backup.
  1. Pipers! I need help once more
    By sean_cummings in forum Celtic Musicians
    Last Post: 18th May 08, 03:59 AM
  2. Other pipers!
    Last Post: 15th June 07, 02:07 AM
  3. Advice from Experienced Pipers please
    By Andy Snow in forum How to Accessorize your Kilt
    Last Post: 24th May 07, 03:14 PM
  4. Pipers
    By Southern Breeze in forum Celtic Musicians
    Last Post: 26th November 05, 08:34 PM
  5. Pipers
    By The Fireman in forum General Kilt Talk
    Last Post: 22nd August 05, 03:49 AM
