14th April 09, 07:47 PM
Argyll Kilt?
Ok, so every tartan kilt I've ever seen has the tartan angled horizontal/vertical.
Has there ever been one with it angled diagonally, like Argyll hose for example?
I assume you would have to order/weave the tartan in square units of measurement, and then cut off the corners so that it becomes a large rectangle, and then continue the standard kiltmaking procedure.
I personally think it would look astonishing, imagine the pleating possibilities!
14th April 09, 08:11 PM
I'm no expert on kilts, but I doubt it. That would be putting the fabric on the bias which would probably be harder to pleat and would definitely fit differently not to mention cost a LOT more because you are only able to use a certain section of the fabric. But maybe I should defer to one of the *many* kilt making experts here...
14th April 09, 08:43 PM
I could see potential... but it wouldn't be easy. It would definitely set you apart.
14th April 09, 08:52 PM
This would look pretty cool. It would be a ton of work to make it into a kilt. You'd have to make a lot of diagonal pieces into squares.
14th April 09, 09:01 PM
I must admit, seeing the MacGregor on a bias does pique my interest.
14th April 09, 09:04 PM
Pleating to a line would look odd... but to the sett the front would look just like the back just one having pleats.
14th April 09, 10:28 PM
Um... I've read about lady's tartan skirts being cut on the bias, but never a kilt.
15th April 09, 01:47 AM
It would certainly look strikingly different and would match a tie and hose which go at the same angle.
15th April 09, 03:27 AM
The kilt would certainly have a great look (although pairing it with any matching items might be overkill).
I'm not sure it would work well, from a mechanical standpoint. Suspect that the pleats would be constantly fighting to return to vertical thread alignment, that is, they might want to hang "sideways." Or maybe not -- hard to tell until some brave soul makes a go at it!
15th April 09, 03:31 AM
I'm still thinking of switching to Roman skirt armor...
By KiltedDawg in forum Contemporary Kilt Wear
Last Post: 29th March 09, 03:19 PM
By beloitpiper in forum Kilt Advice
Last Post: 6th January 09, 12:28 PM
By Kiltedmusiclover in forum Kilt Advice
Last Post: 12th August 06, 01:51 AM
By JBfromBS in forum Kilt Advice
Last Post: 29th August 05, 03:30 PM
