At Panache's request, I am reposting this as one thread rather than the two that I mistakenly created the first time around.
I made myself a walking stick. Does this count as a cromach?
First I cut the crown off of a small antler
Then I drilled holes in the base of antler and top of stick. Started with a small pilot hole and enlarged it to 3/8 inch. The second small hole is for a stabilizing pin to prevent rotation
I cut the head off a ¼ inch carriage bolt about 3 inches long
I had never seen this type of nozzle on 2-part epoxy. It has baffles that mix the glue as it travels through to the tip. This allows you to insert the nozzle into the bottm of the hole and fill from the bottom up. No partially filled holes for me.
More to come
