Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
    2nd August 09
    Maastricht, The Netherlands
    First time kilt making
    Hello everybody,
    I've been nosing around on this forum for quite some time now. I decided to register and post my questions.
    I bought Barb's book a few month's ago, and have been reading it several times. Finally, I got my tartan (black watch) and will start making my first kilt.
    First of all, (I believe every first-time kiltmaker asks this question), what do you think about these splits:
    Measurments:
    waist: 41
    hips: 44
    length: 25,5 (realy, I have a gordon-kilt from the pipe-band which has a total finished length of 28", so I will make my own kilt 0,5" shorter)
    Split:
    waist: 20,5 apron / 20,5 pleats
    hips: 21,5 apron / 22,5 pleats
    Tómmes
    25th May 06
    Kitchener, Ontario, Canada
    Hi Dutch Piper,
    I'd probably go with Waist 21/20 and Hips 22/22
    Also keep in mind, that your Gordon kilt may have a 4 inch rise instead of a 2 inch one.
    Owner/Kiltmaker - Keltoi
    I agree with the splits suggested by slohairt for the measurements that you've given.
    You might want to consider adding 1/2" tp both the waist and hip measurements before you do the splits, though, so that you have room to change size. You'd put the buckles and straps on at the actual measurements but make the kilt 1/2" too big. That would make the splits
    waist: 21 1/2 (apron), 20 (pleats) (or 21 1/4 and 20 1/4)
    hips: 22 14 (apron); 22 14 (pleats)
    I'm really concerned about the length. How tall are you, where does the bottom of your Gordon kilt fall on your knee, and how many inches is it from the top buckle on the Gordon kilt to the top edge of the kilt?
    2nd August 09
    First of all, thanks for the suggestions.
    My Gordon kilt is 28" total length. 2" from the center of the top strap to the top of the kilt.
    When I wear my kilt, the bottom is just above my knee, the kiltstraps are on my waistline (bellybutton).
    When I ordered my kilt (in Scotland) they also didn't believe that I measure 26 inch from waist to knee but it's true. I suppose I just have long legs.
    greetings from the Netherlands
    Tómmes
    2nd August 09
    Flare
    I just finished marking the front apron on my first piece of tartan.
    [IMG]C:\Documents and Settings\Tňmmes & Greetchen\Bureaublad\IMG_0072.JPG[/IMG]
    according to barb's book I shouldn't use a flare less then 1 1/5".
    When I look at my Gordon-kilt, it has a flare of 3/4".
    [IMG]C:\Documents and Settings\Tňmmes & Greetchen\Bureaublad\IMG_0082.JPG[/IMG]
    What do you think is wise to do? Stick with Barb? It looks so wide.
    2nd August 09
    Something went wrong with the images
    2nd August 09
    Red face flare
    I'll try a second time
    2nd August 09
    flare of apron
    The amount of flare depends on the waist-hip differential. If there's a zero difference, there's no flare. If there's a lot of difference, you put in more flare. You don't have much of a waist-hip differential, so 1 1/2" is probably too much. Also, when you draw your chalk line, make a nice smooth curve between the waist and hip chalk marks, not an S curve.
    To give you a better idea of what Barb is saying about the gentle curve here is a photo of the apron taper on a military Kilt.
    Determine the difference at the Waist to the Hip according to The Book.
    Then continue the gentle curve all the way down to the Hem.
    At the hem you should be almost back to perpendicular.
    In your photo you have a straight line from the Hip to the Hem. This will result in an extra large amount of Taper. It will also force you to fold up the Apron Tips a lot more than you would if your taper forms more of a perpendicular angle at the Hem.
  1. Re-making a kilt
    Last Post: 19th September 08, 02:28 PM
  2. making a kilt
    By Ryan Nielson in forum DIY Showroom
    Last Post: 12th July 08, 07:20 PM
  3. Kilt making?
    By singforsam in forum Professional Kiltmakers Hints and Tips
    Last Post: 2nd April 08, 09:54 PM
  4. Making my own Kilt.
    By irishman in forum DIY Showroom
    Last Post: 19th October 07, 06:42 PM
  5. kilt making help
    By kiltie as charged in forum Kilt Advice
    Last Post: 3rd March 05, 01:43 PM
