11th January 10, 05:56 PM
Fringing tartan?
Hi guys. I need some tartan fringed for a plaid. Would I be able to do this myself?
It is in truth not for glory, nor riches, nor honours that we are fighting, but for freedom -- for that alone, which no honest man gives up but with life itself.
11th January 10, 07:05 PM
sure. It takes minimal skill, but a fair amount of patience. Some say "just pull the threads" while others say "cut tiny slits and pull the threads." It is possible to "mess up" if you cut your slits other than perfectly, but you only lose a few threads. Your cat can show you how.
11th January 10, 07:55 PM
If you're wanting fringe a couple of inches deep, say on the edges of a plaid, all you do is clip 1 or 2 threads in from the edges of the selvedges, then pull the cross-wise threads out. It's possible to pull them out without clipping, but it's not as fast.
If you want the edges purled, like this photo from Scotweb:
![](http://scotweb-objects.com/images/magick/items/304x492/padded/Q80/FLanczos/sr_swhdr_pearled_fly_plaid.jpg?1261410536)
then you need to follow these instructions, courtesy of Barb T. in an earlier thread:
http://www.xmarksthescot.com/forum/f...x.html?t=16689
--dbh
11th January 10, 07:58 PM
12th January 10, 06:36 AM
Thanks for very useful info.
12th January 10, 03:23 PM
I don't snip, but I use a blunt embroidery needle to help worry out the threads. Just two or three at a time, carefully and mind-numbingly slowly. But the result is worth it.
Purling is optional, but looks good. Use walkerk's link, but remember to twist until the threads kink every time. And purling shortens the fringe a lot, so if you want two inches of purls, you have to worry out three inches of threads...
Vin gardu pro la sciuroj!
12th January 10, 04:18 PM
When I made mine I used my cat brush ( cleaned of course ;) ). I found the small wires easily caught the threads and made it much quicker.
By Barb T in forum How to Accessorize your Kilt
Last Post: 13th January 09, 08:53 PM
By Barb T in forum Tutorials & How-To's
Last Post: 12th September 08, 07:38 PM
Last Post: 27th February 05, 06:41 AM
