Results 1 to 10 of 17
    21st April 07
    Portland Maine
    A Tin Whistle Interest
    Ive been havign this, Tin Whistle Urge as of late. To me it seems like a very practicle instrument. its small, easy to carry around, and has a nice sound. Also, being about 1% the cost of a set of Bag Pipes does not hurt in anyway.
    I was wondering if anyone here had some experience playing a Tin Whistle. How hard is it to pick up and learn. I used to play an instument, a Tuba, for about 7 years, so I am not compleatly alien to reading music and playing.
    7th May 09
    Oslo, Norway
    If not completely alien to music and playing, it'll take you 10 minutes to figure out te basic fingerings and how hard you ned to blow.
    After that, it's a lifetime of practice to become really good, of course...
    I find tin whistles very practical and easy, but only play a couple of tunes. And now I need to restock on whistles.
    :ootd:
    Vin gardu pro la sciuroj!
    21st April 07
    Portland Maine
    thanks. Im just looking for something easy to learn, that I can pick up a traditional tune or two.
    You know, something I can whip out while kilted and fool around with; something that doenst get me aressted that is.
    7th May 09
    Oslo, Norway
    Just a tip: If you combine a small whistle and a large sporran, you can carry one in the other.
    4th November 09
    Born in Glasgow, Scotland currently S.Yorkshire England UK and part time Gambia W Africa
    I had a small "plastic" one which fortunatley I was able to play by ear. It got lost or broken. Recently I purchased a "proper" one and cant get on with it at all. The fingering seems to be different for some reason. In my opinion it is one of the easier instruments to play if you get your breathing right as both of your hands are doing a similar thins unlike guitar and keyboards etc. Good luck anyway. It is always good when someone play an instrument to liven up an event. I wish I had kept it up. My keyboard has been in the same position for many years ......
    12th May 09
    Southwest Missouri
    Some of them seem to have a mind of their own. I have had two identical Generation whistles which didn't even come close to playing alike.
    If you search the net, you can find all sorts of references to different brands and ease of playing each. Most people who play them do so by ear, and you'll probably have the most fun with it that way.
    Good luck
    Dan
    With your tuba experience, you should have little trouble getting good on the whistle fairly quickly.
    The inexpensive whistles often have horrible quality control, and you might have to play through 10 or 20 Generation whistles to find one that plays well.
    There are a couple options: one is to buy a Jerry Freeman's "tweaked" whistle. He buys whistles off the shelf and modifies them so that they play well, which takes the guesswork out of it. A Freeman tweaked Generation or Feadog is a good cheap way to get a great-playing whistle.
    Or you can shell out the money for a high-end whistle like a Burke. Michael Burke makes wonderful whistles but they cost over ten times what a cheapo whistle will.
    16th September 09
    Toronto, Canada
    I've done a bit of cheap whistle tweaking and it simply involves loosening the plastic mouthpiece from the metal tube. Adjust how deeply the metal goes into the plastic to get the right resonance... kind of like a tuning slide on your tuba.
    As far as learning goes, you can buy a book to help you with the basics and it will have sheet music for a few tunes. You can even find a whistle with book in combination for a better deal!
    Two other pieces of advice: listen to lots of Celtic music to get the feel and buy a "D" whistle incase you want to play with other people because it is by far the most common key.
    - An t'arm breac dearg
    12th May 09
    Southwest Missouri
    Also get a "C". You can play each of them in at least one other key very easily, as well as the associated modal (?) minors
    Enjoy,
    Dan
    What you're describing is simply tuning the whistle: sliding the head out to flatten, pushing it in to sharpen.
    "Tweaking" involves much more: filling the cavity to raise the pitch of the 2nd octave (cheapos often have a very flat 2nd octave), altering the "blade", and altering the "windway".
    Jerry Freeman does all of these things. On some whistles, where the blade is placed too high in relation to the windway, he glues an extra bit of plastic or metal on the underside of the blade and re-cuts the blade, in effect making the blade lower.
    All of these problems with the voicing of cheap whistles comes from the fact that the head is created with a three-part mould, and if the three parts don't align precisely the voicing of the whistle will suffer.
    Many Generations and other cheap whistles are made using old moulds which are worn out so misalignment and "flash" results in a poor-sounding whistle. Freeman corrects all of those things.
  1. Any tin whistle players in here?
    By thatcelticband in forum General Celtic Music Talk
    Last Post: 26th November 07, 12:24 PM
  2. wolf whistle
    Last Post: 10th October 07, 06:28 PM
  3. Jimmy...can you help? tin whistle...
    By cloves in forum General Celtic Music Talk
    Last Post: 26th March 06, 08:26 AM
  4. My First Wolf Whistle
    Last Post: 16th August 05, 02:24 PM
  5. jimmycarbomb and the whistle
    By awoodfellow in forum General Celtic Music Talk
    Last Post: 24th October 04, 09:45 PM
