Results 1 to 3 of 3
    22nd June 10
    West Monroe, Louisiana, USA
    Tapering the fell? Even if REVERSE taper results?
    Hi, Y'all!
    I am currently making an X-kilt - sewing it by hand, and have a question regarding tapering the fell... In the instructions, it is assumed that your hips are larger that your waist... however, despite the fact that I am of Irish/Scot/Welsh (among others) extraction, I seem to suffer from that rare Hawaiian disease called "noarseatall"... my measurements (triple checked) are: Waist (at navel): 48" (Comfortable) or 46" (sucked in); Hips: 45"; Fell: 5"; and Drop: 20" Height: 5'10".
    If I follow the directions exactly, I believe this will end up with a REVERSE taper...
    I intend to do 13 pleats and a 9" (A-shaped to 12" at base) over-apron,to a total of 48" to fit my waist...this will result in a straight taper all the way down...
    Any suggestions (other than losing weight)?
    Thanks.
    Just speaking for a trad kilt, you'd never do a reverse taper. If the hips are smaller than the waist, you'd just use the same measurement for the hips as for the waist.
    19th May 08
    Oceanside CA
    There's been discussion of this in other threads. For example, check this post, and the thread it sits in. There are various ways to measure so that your aprons will fall straight down from your navel while the pleats hug your rumpus. Have fun and be sure to show us how it works out!
  1. Tapering Question
    By Lokishadow in forum DIY Showroom
    Last Post: 7th February 10, 12:06 PM
  2. Tapering Tartan Kilt
    By SergeantBort in forum DIY Showroom
    Last Post: 6th November 09, 10:20 AM
  3. Tapering the fell
    By kd0afk in forum DIY Showroom
    Last Post: 13th July 09, 12:34 PM
  4. A tapering nightmare.
    By Erisianmonkey in forum DIY Showroom
    Last Post: 28th March 07, 02:18 PM
  5. Uk taper
    By dana in forum Contemporary Kilt Wear
    Last Post: 10th March 05, 07:41 AM
