30th July 10, 12:13 AM
How to begin?
Hi!
It's been a while, since my last post on this forum. Mainly because, I've found many answers and good tips regarding making and wearing kilt. Besides, I had many other projects running. But lately, an idea keeps me restless... I would like to try my skills and will on playing Practice Chanter. First I must say I'm an total unalphabet, when it comes to music. OK I can find out which note is written if I have a lot of time available for studying it and I used to play a bit a guitar in Highschool (hm, when was that???). The thing is I don't thing I'll play pipes (to load and no opportunities, ...), but chanter could be something for me to play with. Right now I'm not in the position to pay big money for something really good and I don't think I could find anyone to teach me, in my neighborhood.
I need your advice on some open questions in my mind:
1.) Is it acceptable to buy something cheap (in the range 20EUR on Ebay) to start with?
2.) How much is chanter different from others flutes, like recorder in the way how it's played and tuned? Right, I know there's a big difference in sound. I could get a recorder locally much easier then buying chanter on the Net, just to see if my fingers can do something together with mind and rest of body. And I could find some learning help easier.
3.) Is it possible to learn, a list some basics, from the literature that can be found on the Net? Something for free, for start, would be preferred .
THX
Regards!
Mipi
31st July 10, 12:41 AM
Hmm!
It looks like I'll have to ask Uncle Google...
31st July 10, 05:06 AM
(Assuming you are talking about learning the Great Highland Pipes)
You really do want to buy a quality practice chanter. This has been discussed quite a bit over on another forum (BobDunsire.com) and I have to agree with the general responses there.
Inexpensive practice chanters:- Tend to sound like a kazoo
- Are difficult (or impossible) to tune
- Are made of a low quality wood that splits easily
A acceptable delrin (plastic) practice chanter:- Tends to sound better. Its nice to have an instrument that you enjoy the sound of.
- Is usually fairly in tune
- Near indestructable
Although with that in mind, my answer tends to be shorter: "Buy whatever your instructor says to buy. He may want you to play along with him and having the same chanter means the two can tune together."
Don't have an instructor? For the Great Highland Pipes -- you need one. You really do.
31st July 10, 06:10 AM
Yes you probably would...
I am no expert but here is what I have got from my foray into bagpipes.
The fingering of both the Great Highland Bagpipes (GHB) and the practice chanter (PC) is completely different from that of the recorder or tin whistle. On the Bagpipes, the chanter and drones are fed with air from the bag whereas the recorder is mouth blown. The fingering of the GHB differs from that of other whistley type instruments because the supply of air from the bag is constant. Once you get them started you can't pause between notes. In order to break up a long note into shorter notes of the same pitch a technique of "grace-notes" is employed. These are very short notes of a different pitch which are interjected to create the gaps between longer notes. (There are other complex techniques as well but grace-notes are the simplest). On other mouthblown istruments these short gaps would be created by either tonguing the note or pausing the blow. As I said, neither is possible on the GHB. Playing these grace-notes on the pipes is cleaner and faster if some finger holes are kept covered during playing, hense the different fingering. On the PC it is possible to tongue the note or pause the blow but that's not the point of it. It's designed to allow the bagpiper to practice the correct fingering for the GHB without striking up the pipes everytime.
The difficulty with this different fingering is if a beginner bagpiper has previous experience with whistles or recorders the fingers seem to automatically go to the whistle fingering and it is very hard to unlearn this and adopt the new finger positions. If you on the other hand have no experience of other instruments this makes learning the pipes or chanter that bit easier as you're starting all learning from scratch.
There are many diffent types of practice chanter available, some good, some rubbish. Most cheap ebay chanters are central asian and made of softwoods which absorb too much moisture (it's a very spitty instument) and they split and crack very easily. I wouldn't recommend those at all. Scottish or North American made, hardwood (African Blackwood) chanters are best although although they can be expensive. Mine is made of plastic with a synthetic reed and plays very well. It is reasonably intune (the high A is a smidgen flat) but mostly it's very robust which suits me as I travel quite a bit. I would definately recommend getting a "poly-penco" (plastic) PC to start with.
If you haven't got an instructor handy and I haven't either, I would recommend getting "The Highland Bagpipe Tutor Book 1" from the National Piping Centre online shop. It's quite expensive at £25.00+p&p (about 30EUR) but it's the best book I have found and I've looked at a few. I've also not found it any cheaper elsewhere.
It is very detailed and takes you though all the basics of the PC including music notation theory and applies the written score to your instrument's finger positions so you learn to read the dots as you progress on your chanter. The National Piping Centre also do a complete starter pack which includes a Poly-penco, St Kilda PC and the above book for £39.95 (48EUR) I have the book and a poly chanter from a different maker and supplier and mine came to £44 (52EUR) in all. I wish I'd found this source first as that is excellent value for the quality of chanter alone...
You do not need to buy Book 2 unless you are going to make the transition to Bagpipes proper. If you do, I'll give you a pointer there too.
A word of warning. I play a few instruments and assumed the bagpipes would be a doddle. What can be hard about an instrument that can only sound nine notes?
It is the hardest instrument I have ever attempted, but then, I think that's what makes it such fun... It is DEFINATELY a challenge and without argument you would be better with an instructor. There is online instruction available and some good instructional clips on You-tube. It's not as good as a proper one-to-one instructor but in Slovenia I would imagine bagpipe teachers are a bit thin on the ground.
Good luck with it!! You'll enjoy yourself I'm sure. I'm having a ball with my adventure.
31st July 10, 07:44 AM
Thanks both of you.
Just as I suspected. I'll leave this idea aside for a while and play a bit with recorder, at least until I found the way how to learn PC. Besides, I found that PC and recorder in general are tuned differently, which means different griefs to play the same note (additional complication besides "Grace-notes" ), I guess.
3rd August 10, 06:39 PM
Much better to get a good practice chanter, and there's certainly nothing wrong with a good plastic chanter, like a Dunbar polypenco chanter. And it's definitely a different instrument than a recorder.
What about finding someone on XMarks who is willing to give you some lessons via Skype? Wouldn't matter where you were in the world, as long as your computer has a little video camera and so does your teacher.
I'd be happy to volunteer to teach you, if you ever want to learn. Just PM me.
3rd August 10, 07:05 PM
You have received really good advice here; particularly from English Bloke. My concern is that you don't think you will (or don't want to) play the GH Bagpipes. So my concern is that you will tire of the practice chanter (PC). I only say this because I haven't met anyone who hasn't started the PC with the intention of moving on to the pipes. I would recommend that you stay with the recorder or tin whistle. The tutors (books) will definately assist you with the PC, but an instructor in my view is a must. Good luck with whatever decision you reach.
3rd August 10, 11:51 PM
Well, I don't say I wont play GHB, but most likely there will be no opportunity here in Slovenia. Playing it at home make no sense (laud), I think. It could happen, someone calls the Police to silence me
Skype definitely is good alternative for remote learning (tutoring). So Barb, I really appreciate and I'm thankful. Coming this from you, means me a lot.
Let me think.... get PC... try on my own for a month or two... and who knows...
Regards!
Mipi
4th August 10, 08:27 AM
Mipi, if you're not too busy on the weekend of the 20th August, why not go up to Czech Highland games where you might meet up with pipers nearer you than most of us. Vaclav Rout, the organiser, is a very keen piper and there is a big piping competition.
4th August 10, 09:28 AM
Not that I have any ambition to play the GHBP, but a well meaning relative gave me one of those cheap wooden chanters. I'm a reasonably capable woodwind player but the only this that it's good for is scaring the cat.
I agree with the experts...GHBP is a real challenge.
Best
AA
By xman in forum General Kilt Talk
Last Post: 7th April 10, 09:13 AM
By Panache in forum Craig's Corner: The Humorous side of Kilts and XMTS
Last Post: 28th August 09, 02:20 AM
By druid in forum General Kilt Talk
Last Post: 28th May 08, 08:16 PM
By J.B. Simpson in forum General Kilt Talk
Last Post: 21st March 08, 09:01 PM
By Arizona Scot in forum How to Accessorize your Kilt
Last Post: 23rd December 07, 09:53 PM
