2nd November 10, 11:58 AM
Kilt Pin
Decided to try my hand at turning a basic kilt pin out of a piece of white ebony I had laying around. Here is what I came up with...
Next time around I may try and get fancy with it.
"just as the Son of man did not come to be served, but to serve, and to give His life as a ransom for many." Matthew 20:28
Clan Maclachlan
Clan Hanna
2nd November 10, 01:21 PM
Hey, that's great. I'ved carved a couple but had not turned one yet.
Thanks for the inspiration!
2nd November 10, 11:15 PM
On the next one I plan to remove that large hunk of plastic over the pin and use epoxy and small brass screws to hold it to the wood. For now, as a learning project, I'm happy with the results.
Clan Maclachlan
Clan Hanna
3rd November 10, 07:51 AM
I just use 5" epoxy for the several I've made. So far no problems with them coming loose.
3rd November 10, 09:33 AM
It looks pretty good. I like the different and original designs for kilt pins. It gives the wearer some individuality...not that the kilt doesn't already do that, unless you are with a rabble of kilties.
I would recess the pin into the wood a little to keep it from flopping side to side.
T
4th November 10, 03:01 AM
T
I had actually thought of that after all was said and done so next one will be milled to accommodate that change.
Clan Maclachlan
Clan Hanna
