Results 1 to 3 of 3
    12th December 10
    Fairbanks, Alaska
    what about the bottom of the stitching in the pleats?
    I think I want that line to be about 2" above the widest part of my hips right before lunch. Right after lunch that will put the bottom of the stitching right at the widest part of my hips.
    That seems to be the sweet zone for maximum "swish"
    Am I missing anything important?
    Thanks
    EDIT:
    thsi thread can be locked. The forward going solution is here: http://www.xmarksthescot.com/forum/f...il-imgs-64333/
    16th January 06
    London
    The stitching of the Fell ( the part from the top of the kilt down to theend of the stitching) is generally measured to be about one third of the full drop of the kilt, but a often this is adjusted to be "on" the point of the widest hip measurement.
    The reason for this is that the pleats can swing free below that point, if the fell is stitched too low there won't be a good swing , and stitched to high the kilt will probably swing with more of a kink and may even crease more easily.
    All these measurements are based on the judgement of the maker as well, and there is no absolutely "exact" number.
    25th December 08
    Lotus Land
    Use the kilt straps to loosen the kilt after a big meal and keep it hanging properly from your waist. That'll keep it looking its best at all times.
  1. Good hang of pleats and stitching
    By mano1979 in forum Professional Kiltmakers Hints and Tips
    Last Post: 22nd December 08, 06:14 PM
  2. How do I end my stitching?
    By ardchoille in forum Professional Kiltmakers Hints and Tips
    Last Post: 29th September 08, 03:39 PM
  3. Stitching
    By emeraldfalconoflight in forum Kilt Advice
    Last Post: 11th August 05, 07:41 AM
  4. Bottom edge
    By Tiran in forum Kilt Advice
    Last Post: 5th June 05, 08:37 PM
  5. help! bottom edge
    By mcnice in forum Traditional Kilt Wear
    Last Post: 3rd December 04, 01:08 PM
