Results 1 to 10 of 13
Thread: Cap Badge Size
    4th February 10
    Cap Badge Size
    Greetings,
    Recently recieved what I had originally thought was a clan crest cap badge but it appears to be slightly on the small side.
    The badge is 1 5/8 by 1 7/8 or just a little over one and a half inches wide and almost two inches from the top to the bottom the garter tip.
    This is an antique, although I don't know how old. It's marked sterling silver on the back with no other marks, so I am not quite sure how old it is.
    Were cap badges of the past slightly smaller than the standard pewter ones we see today?
    Thanks,
    8th February 04
    Perhaps it was a bit smaller to save a bit on Silver costs...
    4th February 10
    I suppose It's possible. It's an odd size. Seems small to be a cap badge but too large to be a pin.
    Granted I am accustomed to looking at the largish cap badges we see today so maybe this was more the accepted size in the past?
    15th May 08
    Near Frederick, Maryland
    These current silver cap badges are 1 5/8 X 2 1/8
    http://www.crestbadges.com/index.html
    These pewter ones are listed as 1.6 X 2
    http://www.scotweb.co.uk/products/clan-cap-badge/
    Seems yours is in the normal range.
    4th February 10
    Thanks for the info.
    I don't think there is a standard size bonnet badge, particularly with the older ones. Funnily enough, I have noticed that the Scots of the older generation have tended to go for the larger sizes and mine is(just measured it) a wee tad over 2 inches across and was made in 1899. Yours sounds as though it fits in the pretty normal size range.
    4th February 10
    Thanks Jock et al.
    Here is picture comparing a rather modern pewter? (left MacLachlan) and the antique silver (right Henderson) cap badges.
    As you can see, there is a considerable size departure. The MacLachlan is nearly 2.5 from top to bottom of garter and is 2" accross. It also weighs a ton. The Henderson is sized, as mentioned above...just under 2" tall.
    My glen will probably be a lot more comfortable to wear with the Henderson badge.
    4th February 10
    I put the small badge on the cap, and despite it being a lot smaller than what I have been accustomed to, it doesn't look bad. I was concerned it was going to be lost in the cap.
    22nd January 07
    Morganton, North Carolina
    I have a MacMillan badge of the same type. I find that I like it better than the modern badges. Good find!
    David
    4th February 10
    Quote Originally Posted by davidlpope View Post
    David
    Thanks David.
    I have gotten to like it now. When I first saw it I was worried it was too small, but once on the cap it seemed fine.
    Only issue now is that I see someone has coated it with acrylic or something to keep the silver from tarnishing. I've heard this suggested before, for large silver collections but I don't think a little cap badge is too difficult to polish from time to time.
  1. Size?
    By sharpdressedscot in forum USA Kilts
    Last Post: 26th April 08, 05:44 PM
  2. SWK size
    By mbhandy in forum General Kilt Talk
    Last Post: 28th July 07, 07:31 AM
  3. Set size set?
    By MACKAY in forum General Kilt Talk
    Last Post: 29th November 05, 06:51 AM
  4. size
    By mcnice in forum Contemporary Kilt Wear
    Last Post: 4th September 04, 12:07 PM
