9th March 11, 12:15 PM
Neck Ties
Hello everyone!
I'm working on putting together a kilt wardrobe. I have a burgundy five button waistcoat on the way, which will look nice with my BW tartan kilt. My question is, what color neck tie would look good? Not match, but complement. I have several pair of hose, a tan or bison is what I normally opt for, with dark blue garter ties. Normally I would choose a red or red paisley neck tie. But with the deep red/burgundy waistcoat I think it might be a little overbearing.
So, what say you?
Thanks,
Seth
9th March 11, 12:16 PM
Wear a dark blue and green striped tie. Or just a solid dark blue.
9th March 11, 12:40 PM
I'd urge you to think about these ties as an addition to your regular wardrobe, instead of focusing on trying to match the tartan in your kilts. A couple nice repp stripes with navy, gold, dark green, burgundy, etc. is a good place to start. Perhaps a "Churchill Dot" in a dark, rich color. Next a small fouillard pattern. To top it off, a nice solid color, maybe with a bit of texture. Unless one wears a tie everyday for work, you'll find that you only need 5-6 ties to look sharp with any outfit you'd pull out to wear.
If your waistcoat is burgundy, though, I might wear a non-burgundy tie just to break things up a bit.
Best of luck!
David
9th March 11, 03:08 PM
Best of luck!
David
Well stated David, and I concur completely. Ben Silver and Brooks Brothers are great resources for the specific neck ties David mentions - not too mention for dress shirts as well. And again, don't worry about matching - it looks far better when one does not! Good luck mate!
Yours aye,
9th March 11, 03:16 PM
I would suggest an ABF tie or the newly sanctioned XMarks tie would be splendid additions to your kilting wardrobe
9th March 11, 06:10 PM
The four-in-hand is too lopsided for my tastes, so I have all my ties long enough to tie half-Windsors with trousers. I have a few ties that are short (regular length) that I can only wear with the kilt. To shorten your ties, try tying a Double Windsor.
Kenneth Mansfield
NON OBLIVISCAR
9th March 11, 07:16 PM
What he said. Double Windsor will use up about 2-3" more tie but the knot is large. If you have a small neck it might look too thick.
Rondo
9th March 11, 12:49 PM
Hold on for a while, post a picture of yourself with the kilt, jacket, & waistcoat, then stand back and wait for the advice! It'll be good!
9th March 11, 02:48 PM
Neckties
Here's another small matter to consider - tie length.
With a pair of pants your tie should stop just at your belt buckle, but a kilt rises a lot higher - up around your lower ribs in some cases. Some ties are shorter than others - find them, and learn to tie your tie so that it doesn't hang way down and ruin the look. Three times around instead of two. Silk will be less bulky than polyester.
Just another little thing to know. That's why this forum exists.
9th March 11, 03:05 PM
Very good point. Some of my ties can be worn with the kilt if I tie a half-windsor knot. With others, even with a half-windsor, I end up tucking the other end into the placket of my shirt because they are a bit longer.
By CMcG in forum Show us your pics
Last Post: 29th January 12, 07:32 PM
By Mikilt in forum How to Accessorize your Kilt
Last Post: 13th October 10, 09:33 PM
By scotchmaster in forum How to Accessorize your Kilt
Last Post: 2nd April 09, 05:10 AM
By Derek Conley in forum How to Accessorize your Kilt
Last Post: 16th December 08, 12:03 PM
By Larry124 in forum How to Accessorize your Kilt
Last Post: 12th June 08, 03:12 AM
