Results 1 to 10 of 27
    NorCalPiper is offline Membership Revoked for repeated rule violations.
    25th December 07
    Sacramento, CA
    Moving the buckles-TAKE NOTE
    One thing thats an easy resort for a kilt thats gotten too big is to undo the buckles and move them back to accomidate tightening. Seems easy, but this is a tricky processs. Next time you see someone wearing a kilt with the sporran/belt loops mis-aligned to one side, you'll know what I mean. A kilt is a custom constructed garment that utilizes a formula for fitting its owners measurements.
    The underapron is the key. Some kilts have the be........Sorry for the break-my wife just called and the car has blown a tire and I have to go take care of this. I'll continue this when I return. If anyone wants to share their tips on this subject, feel free.
    5th November 10
    Riverside, California, USA
    Is this the right place? This is the new cliff-hanger story thread, right?
    MEMBER: Kilted Cognoscenti
    25th December 08
    Lotus Land
    ooo ... ooo ... Good time to get popcorn.
    11th April 10
    Carmichael, CA
    If you are hopeful you will shrink (up to 4 inches) but do not want to delay ordering a kilt is it better if the kilt is pleated to the stripe and has no belt loops. That way the apron stripe can be centered and the back looks fine.
    25th December 08
    Lotus Land
    Quote Originally Posted by McElmurry View Post
    While this can be advantageous, I would likely defer to the sett first to be sure it will look good that way at all. It is best to order the kilt at your ideal weight when you reach it.
    I am so glad that you all posted, I didn't want to be the first.
    I don't have any special sewing skills. But I was taught to sew buttons on 51 years ago and I can put a new zip in a pair of Levi's using a hand-cranked Singer.
    And I can change the buckles and straps on a kilt in 59 minutes. I find the process straightforward, rather than tricky. Maybe, I'm doing it wrong.
    12th December 10
    Fairbanks, Alaska
    Here is mine. I bought one a little too big so I could be sure of the length to order for my good kilt.
    I moved each buckle three inches. I cut a new hole for the inner apron strap to pass through. The box pleat lays on the very front of my right thigh and the end of the inner apron reaches almost to the back midline of my left thigh.
    The "left" belt loop lays almost exactly on the middle of my spinal column, the "right" belt loop is within an inch of being all the way out on my right hip.
    When I do it, I move the buckle on the right side, but the strap on the left side. If they are moved by the same amount the centre back stays in the same place. Also you don't have to cut new holes.
    12th December 10
    Fairbanks, Alaska
    Dang it. I almost did that with mine. I was afraid the loose end of the inner apron wold sag below the bottom of the rest of the kilt.
    Is this a non issue, something that only works if you move the strap a little bit, or do you cut off the excess?
    15th April 07
    State College, PA
    I would say you could move the strap about 2" without concern. If you move it more, the edge of the under apron may feel uncomfortable on the back of the leg.
    Wallace Catanach, Kiltmaker
  1. Moving buckles - how much is too much??
    Last Post: 11th June 10, 05:00 AM
  2. Operation Moving Buckles
    By nh_maclean in forum Show us your pics
    Last Post: 15th October 09, 10:12 PM
  3. Just an eye note
    By Bill in forum Miscellaneous Forum
    Last Post: 8th February 07, 04:44 PM
  4. Another sad note ...
    By Derek in forum Miscellaneous Forum
    Last Post: 17th May 06, 11:46 AM
  5. just a note ...
    By awoodfellow in forum General Kilt Talk
    Last Post: 6th August 04, 06:46 PM
