21st June 11, 01:43 PM
Cable hose finally finished
It has been three years in the making at odd times, in the evening and on he train. I'm still having problems with the photography. Still here it goes. One will see that I was experimenting with one understanding (an incorrect one) of hose tops. I was attempting to allow the fancy cable work to outlast the heel and toe. My first attempt at this had problems with riding up, hence the sturip.
I tried holding the camera away from myself and aiming by guess and by golly, this is the only one to come out.
I also got infected by another thread here concerning "highland moccosins" and tried making a pair. This is actually the second attempt. Perhaps if I shake the computor, the other photo might fall out. Hopefully more to come.
Elf
-atr: New Zealand proverb
21st June 11, 01:45 PM
Mm. Can't get the pictures here.
21st June 11, 02:10 PM
Nice work. Fascinating design. Good for you!
21st June 11, 02:14 PM
Ha! I see them now. Nice work!!
21st June 11, 02:27 PM
I like the cables and the color, too. You've done a good job.
Is the stirrup uncomfortable under your heel?
--dbh
22nd June 11, 10:51 AM
Thank you for the replies. The stirrup goes under the instep, not my heel. I do feel the it a little when i first put on a shoe, but is not a bother walking around all day like yesterday on downtown sidewalks. Also by the way, that was with a different weight foot sock; one of the advantages of the system.
However, I have another plan for next time. I will cast off above the foot and then pick up stitches again for the heel and toe. That way I can rip out a worn out foot and then once more pick up stitches and replace the foot. As one may tell, i am quite commited to experimentation and chagrinned to do two projects the same way.
Elf
22nd June 11, 02:47 PM
You might want to try an Afterthought Heel. It would work for what you're wanting, I believe.
--dbh
22nd June 11, 02:54 PM
Very nice way to keep the nice upper part while being able to replace the high wear parts. I'm really impressed. Well done.
22nd June 11, 06:58 PM
Beautiful knitting!
However, I have another plan for next time. I will cast off above the foot and then pick up stitches again for the heel and toe. That way I can rip out a worn out foot and then once more pick up stitches and replace the foot. As one may tell, i am quite commited to experimentation and chagrinned to do two projects the same way.[/QUOTE]
Beautiful knitting. Design is very clever! You put a lot of work into these, and it shows.
I love a knitting challenge, too. What I have done with my heels and toes is to knit a strand of woolly nylon (sold for use in serger machines) along with the yarn. The stress points are then reinforced. It does not change the gauge. There's a slight color variation, like flecks of a tweed.
Your technique, to cut away a worn-out foot and knit on a new one, is often used to extend the hems and cuffs of children's sweaters.
22nd June 11, 09:55 PM
Look great to me!!
I've not yet figured out how to knit simple garter ties...so the fact that you can make something tubular with design is absolutely a mystery to me. Well done. I like the two piece design!
By sydnie7 in forum DIY Showroom
Last Post: 8th July 10, 09:24 PM
Last Post: 4th November 09, 02:56 PM
Last Post: 10th May 09, 10:41 AM
By jordanjm in forum How to Accessorize your Kilt
Last Post: 24th May 07, 09:02 PM
Last Post: 23rd March 07, 06:56 AM
