Results 1 to 9 of 9
    28th September 09
    California
    New one in 100% Cotton.
    The front.
    The back.
    The reverse Captain Morgan.
    100% cotton, sewn down pleats. As far as the tartan it's technically a fashion tartan, but if you replaced the blue in Royal Stewart with red, this is it.
    Harold Cannon's Avatar
    Harold Cannon is offline Oops, it seems this member needs to update their email address
    15th April 08
    Alabama
    Looks good! My MacMillan Dress kilt is cotton. A cotton kilt is quite comfortable here in Alabama
    kc8ufv's Avatar
    kc8ufv is offline Oops, it seems this member needs to update their email address
    5th August 10
    Toledo, OH
    Mostly looks good. Though, it looks like the pleats in the back look about like this: //////
    28th September 09
    California
    Quote Originally Posted by kc8ufv View Post
    Hmm.. Well, my right leg IS 1cm shorter than the left causing my right hip to be that much lower than the left. Could just be wearing it crooked.
    EDIT: Nope, sure enough, the pleats are ever so slightly crooked, and my short leg thing just accentuates it.
    Thanks for the feedback.
    Good on ya. Congratulations on your kilt.
    From a kiltmaker, one of the factors that is causing your pleats to hang ////// is the way you sewed the pleats in the Fell.
    If you will look at the Fell area you can see that the horizontal lines of the Tartan do not line up. They give a sort of stair step look.
    If you take a lot of care insuring when you sew that the lines of the Tartan are perfectly aligned it will allow the pleats to hang a bit straighter.
    Also, with your large thighs it may help the pleats to lay smoother in the front and sides if your apron were a bit wider. On a Traditional kilt the apron is about 1/2 of the waist.
    All and all a good kilt. Congratulations.
    26th November 04
    Dayton, Ohio
    Where did you find the material? When I have found fashion tartan material like that I am concerned it will be too light weight to make a kilt.
    Mike
    Mickey is offline Oops, it seems this member needs to update their email address
    13th April 11
    St. Louis, MO
    It's a heck of a lot better than the none that I've made so far;)
    28th September 09
    California
    Quote Originally Posted by Mike in Dayton View Post
    Mike
    Joann fabrics, out of their platitudes collection. It's a little light, but nowhere near as light as their flannel selection. You have to be careful with them, they just see "plaid" and stack it all together sometimes.
    Thanks Steve, long time no talk.
    Quote Originally Posted by Mickey View Post
    Thanks.
    kc8ufv's Avatar
    5th August 10
    Toledo, OH
    Mike
    Quote Originally Posted by The_Tailor View Post
    FYI, you may have better luck in their larger stores, like JoAnn Etc. I bought some there that was on sale cheap that I intend to use for practice on my first attempt making a kilt from TAoK, (have been rather busy with other things going on that I haven't even had a chance to take it out of it's shrink-wrap, though), and I know what I bought will be a little light weight. Next time I drive north from work, I might stop at the big one in Taylor. The ones in Toledo, Oregon, or Maumee are all smaller, and each has a different selection.
  1. How do you dye a cotton shirt??
    By Tony Miles in forum DIY Showroom
    Last Post: 9th August 09, 04:25 PM
  2. Greetings from the land of cotton,
    By Swampthing in forum Kilt Board Newbie
    Last Post: 10th April 09, 06:00 AM
  3. Robertson Red in cotton
    By Prester John in forum Professional Kiltmakers Hints and Tips
    Last Post: 19th May 08, 07:53 PM
  4. Cotton kilt
    By herminator in forum Show us your pics
    Last Post: 17th February 06, 05:36 AM
  5. Cotton Kilts
    By davedove in forum Kilt Advice
    Last Post: 29th August 05, 01:27 PM
