Results 1 to 10 of 14
    9th September 11
    Penacook, NH
    Bit by the Dirk bug
    So i just can't fight it. I want to make a dirk. Now I flew through making my sgian duhb, and i surely do like it. But for something like this, I want to take my time and really do a good job on it.
    So I started tonight selecting a good piece of steel. A length of tool steel was selected. I cut a piece down to 19 3/4 inches by 3 inches by 1/8 inch.
    Now I didn't want to jump right on a grinder, because the heat would de-temper the steel, so I made a couple crude cuts with a liquid cooled band saw. Then I rough ground the basic shape I want.
    I didn't get any farther, because I didn't have the antler with me I want to use for a handle. In the next few days, I want to plan out the hilt, the handle and pomel and really take my time crafting each part. I plan on this being a working blade and taking it hunting and camping (preferably with a flintlock rifle i have my eye on).
    As stuff happens, I'll keep you posted.
    But first, I need to figure out a better way to transport the stupid thing on a motorcycle. haha
    Chirs is offline Oops, it seems this member needs to update their email address
    11th March 11
    Barrie, Ontario
    Re: Bit by the Dirk bug
    Nice. I'm looking forward to the saga.
    14th May 08
    Slovenia
    Hopefully this will be a step-by-step instructions.
    Brasilikilt's Avatar
    Brasilikilt is offline Oops, it seems this member needs to update their email address
    29th February 04
    Portland, Oregon
    Tool steel...liquid cooled band saw?? Sounds like you work in a machine/fab shop or have some pretty nice toys at home :-)
    I sure hope you jazz the handle up with some brass fittings or poured pewter!
    Wear your kilt proudly, but carry a big stick
    19th July 09
    Central Illinois
    Just a reminder-a dirk is NOT just a big sgian. Think balance, differential tempering, fuller positions, point types, grind type and what you plan to use it for...
    Also, I would de-temper via a torch-that way, you can start from the bottom up and ensure you get the temper you want, instead of something questionable, and it is much easier to work. Just me. The type of steel you buy can guarantee a temper will take-how you get it there is usually the end of the process.
    A pitchfork is a polearm too!
    20th August 11
    SW Oklahoma
    Quote Originally Posted by BuchananBiker View Post
    ... by 1/8 inch.
    is that a just a trick of the camera angle or is the steel 1/4"?
    9th September 11
    Penacook, NH
    Nope, not a trick of the light. Just a typo while I was working third shift, after finishing up second shift at another job.
    Good catch!
    29th February 04
    Portland, Oregon
    I second what Mark E. said, but depending on what type of tool steel you have, un-tempering by torch may not be the way to go.
    While this would be fine for a lot of steels, some steels air harden and could get so brittle that it cracks or shatters.
    If possible, find out what kind of tool steel you have. If there's no sure way of knowing, you could always cut off a small piece to test.
    9th September 11
    Penacook, NH
    So I've pondered this a bit. Since I plan on bringing this hunting, camping and hiking I'm going to rethink the hilt and handle a bit. I'm still going to give it an antler grip, but I'm going to make it a full tang. This dirk is going to have a hard life, so this just seems to me to be the right way to go.
    And being a bush tool and not meant for sword fights, it's gonna get a scandi grind.
    With any luck, I'll have time tonight to do a little more work on it.
    30th June 10
    San Francisco, CA, USA
    If you WERE going to be traditional and have it represent a cut-down broadsword or backsword blade, it would be a "Moran" style or convex edge.
    What really drives me buggy about DIY dirk projects is the way they're so often misproportioned -- the biggest (literally) things being handles 'way too long, and blades much broader and thicker than sword blades were.
    Historically, dirks weren't "meant for sword fights" either: They were stabbing/slicing weapons meant for puncturing and cutting, um, meat. If you ever want some good clues as to how they probably were historically used, the dagger-fighting sections of surviving medieval and Renaissance-era European training manuals would be useful.
  1. dirk
    By taplin001 in forum Traditional Kilt Wear
    Last Post: 13th July 10, 12:29 PM
  2. dirk
    Last Post: 18th June 10, 09:04 AM
  3. A Dirk
    By ChattanCat in forum How to Accessorize your Kilt
    Last Post: 2nd February 10, 01:39 PM
  4. New Dirk
    By PiobBear in forum DIY Showroom
    Last Post: 2nd March 08, 03:42 PM
  5. Dirk
    By Casey in forum How to Accessorize your Kilt
    Last Post: 7th October 04, 10:43 AM
