Results 1 to 8 of 8
    NorCalPiper is offline Membership Revoked for repeated rule violations.
    25th December 07
    Sacramento, CA
    Interesting things you find when working on other maker's kilts....
    I have worked on just about every kilt makers kilt at this point (90% are just buckle moves, the rest are re-linings), and I'm always learning bits and pieces of technique when I do. It really is true that while kilt making has a standard as far as construction goes, its the smaller details that become unique to individual makers.
    I recently replaced a prong-less buckle on a kilt made by Burnett & Struth. While I didn't have to take anything apart excepting the buckle strap, I did notice the INCREDIBLE fringe on this kilt. It was triple layered, but all layers we trimmed perfectly, and the fringe was....stiff (for lack of a better word). Almost like it had been brushed and hair sprayed straight. It looked amazing, and as a I ran my finger through it, it snapped right back to its form! Is there something I'm missing to achieve this effect? The first layer is 1/16 of an inch, the second under 1/2 inch, and the third layer under 3/4ths of an inch.
    6th February 10
    U.S.
    Re: Interesting things you find when working on other maker's kilts....
    Wow, I wish the fringe on my kilts were like that! I would ask Paul Henry, as he makes kilts with a triple fringe, that does appear to be stiff.
    25th December 07
    Sacramento, CA
    I personally just do a double fringe and have always liked it......until now! M-U-S-T L-E-A-R-N....
    CopperNGold is offline Oops, it seems this member needs to update their email address
    22nd September 11
    Oregon Coast
    Could it be felted and then some sort of permanent sizing applied?
    7th July 09
    Melbourne,Victoria Australia
    I have two kilts made by Highland Clans which also have the fringe you describe Josh. One is 13oz HOE cloth and the other Lochcarron 16oz, but both bounce back as you say
    21st June 06
    Cambridge, ON, CANADA
    I've found enough "surprises" when altering that I now prefer to only work on ones I've made myself! Can't quite make it an absolute rule, but I WISH I could.
    One time I had an apron almost apart to enlarge a kilt before I discovered that a 6"x8" piece had been cut out of it ... looked like just about the right size for a new set of buckle tabs.
    And a few years ago I was altering a number of Burnett's & Struth kilts for a pipeband and they were all made with the wrong side of the tartan out!
    Ron.
    Quote Originally Posted by CopperNGold View Post
    I wonder if it could be 'Fray check' or similar - it is designed for use on open edges, to prevent them undoing themselves.
    I have been hesitating to make fringes due to concerns about them becoming matted or going into self destruct - I considered using waterproof white wood glue, diluted down - but 'Fray check' might be the safer option.
  1. more interesting Ebay things
    By OC Richard in forum General Kilt Talk
    Last Post: 6th June 11, 09:39 AM
  2. Interesting find...but not really a kilt
    By DougC in forum General Kilt Talk
    Last Post: 24th December 09, 09:39 AM
  3. Barb may find this interesting :)
    By meinfs in forum Miscellaneous Forum
    Last Post: 30th June 09, 09:21 AM
  4. An interesting find!
    By sirdaniel1975 in forum How to Accessorize your Kilt
    Last Post: 22nd August 06, 06:45 AM
  5. the things you find while Googling...
    By UmAnOnion in forum Kilts in the Media
    Last Post: 27th April 06, 12:46 PM
