Results 1 to 10 of 40
    16th May 11
    Tupelo, MS
    DIY attempt number 5
    Here we go again! I started again today. I almost screwed this one up big time before the chalk even touched it. When measuring, I used the "1" mark rather than the end of the tape. I do this often and it works great as long as you do indeed add 1 to your measurement. After I'd cut out the waistband strap, I measured both pieces. They were 24 inches long but should've been 25 inches. Luckily, I had enough allotted for the hem that I could get 3/4 of that inch back. It will now have a shorter hem but hopefully will be okay. More to come with progress. I'm off to stitch some pleats.
    A stranger in my native land.
    Kilty as charged.
    29th April 09
    Wichita Falls TX
    Re: DIY attempt number 5
    Measure twice, cut once. Or in my case: measure twenty times, then cut. Especially if it's for someone else.
    Merry Christmas!
    Jimbo
    "No howling in the building!"
    Ah, yes. "Measure twice, cut once." How often have we all not headed those words. No permanent damage done.
    16th May 11
    Tupelo, MS
    Indeed! I was ready to smash my head against the table when I realized what I'd done. Luckily I calmed down and figured out that the whole thing could still be salvaged. Cooler heads prevail. That's another one I should heed more often.
    Kilty as charged.
    25th December 08
    Lotus Land
    When measuring for accuracy (and let's face it, with a kilt you need to be very accurate) it is better to use a point along the tape rather than the end of the tape as your starting point. I usually use the 10cm point rather than the 1cm point. Mistaken measurements are usually very obvious then and I can adjust accordingly.
    16th May 11
    Tupelo, MS
    But when you catch your mistaken measurements after cutting, it's usually too late. I was lucky.
    Kilty as charged.
    25th December 08
    Lotus Land
    Quote Originally Posted by Aspiringloser View Post
    Yes indeed. what I meant was that I notice any discrepancies as I'm measuring. It's obvious instantly.
    14th May 08
    Slovenia
    There is a joke related to wrong cutting in my home land:
    "I've already cut twice and it's still to short"
    Oh yeah.. kilt looks good!
    9th March 09
    Gardner MA USA
    Wow. You are doing a great job!
    16th November 11
    Massachusetts, USA
    What Tulloch said. The pleats look perfect!
  1. DIY attempt number 4
    By Aspiringloser in forum DIY Showroom
    Last Post: 19th December 11, 09:24 PM
  2. Kilt Number Two
    By Doftya in forum DIY Showroom
    Last Post: 21st October 09, 07:54 PM
  3. number 19
    By Robert Lamb in forum General Kilt Talk
    Last Post: 30th November 06, 04:02 PM
  4. Here's number 2!!
    By JimB in forum DIY Showroom
    Last Post: 8th November 06, 04:25 PM
