Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
    24th September 04
    A 60 year old kilt re-build
    Many of you remember when I did a long pictorial which is part of this thread (click here), where one of our members asked if a kilt should change size as it is worn. In that thread I tested the kilt and then rebuilt it for him to include the stabilizer and interfacings which were missing.
    And some of you may remember that I am now the Regimental Kiltmaker to the Canadian Scottish Regiment.
    We have been getting kilts here at the shop for repair. Some are old and some pretty recent. All of these kilts have suffered far more abuse than what a kilt would normally go through. They are worn in rain, mud, on parade and in the field. They are issued to new troops with very little knowledge of how to care for a kilt and because they are issued the troops have little concern in taking care of them.
    Here is just one of the kilts that has come in. Many of the Regimental kilts look like this when I get them.
    This kilt was made by a reputable traditional kiltmaker here in BC and is only about 12 years old.
    Today I began the repairs to a kilt that at first glance I thought was new and would need new straps and buckles and a new waistband. Can you imagine my surprise when I found this label inside.
    Note the date stamped in the lower right corner. That's right, March 1952. That makes this kilt 60 years old.
    Here is what a 60 year old kilt looks like.
    A pretty dramatic contrast to the kilt in the first photo.
    I thought some of you would enjoy seeing what it takes in the way of construction to allow a kilt to survive 60 years of total abuse.
    Forum Owner
    14th January 08
    San Antonio, TX
    Definitely looking forward to following this threads course. Color me eagerly fascinated already in anticipation.
    3rd March 10
    43*N 88*W
    Quote Originally Posted by ForresterModern View Post
    I am astounded that that kilt is over 1/2 C. old, and can't wait to take a peek at it's "guts".
    ith:
    Sorry folks, I was working on the forum as Steve Ashton and forgot to log out and log in as The Wizard.
    OK, let's begin by evaluating this kilt the same way we did with Tobus's Kilt.
    One of the first things I noticed on this old kilt was the hardware.
    Notice the old style two prong buckles.
    One strap is broken off and one missing entirely.
    Also notice that the green horse blanket binding that is used as the waistband on Regimental kilts is worn through.
    At first glance I thought that this kilt looked pretty good. Most of the stitching is tight and intact. There is very little stretch between the buckles. The fabric itself has only one small hole from a kilt pin getting caught on something.
    Then I noticed something strange.
    Here is a shot of the right edge of the outer apron. You can see that the strap hole is torn.
    But the strange part is the right (right as in the photo) edge of the apron where it is sewn at the Fell.
    Notice that the yellow vertical line seems to wander all over the place.
    Here is the other side of the same apron.
    On this side of the apron the yellow line is fairly straight and meets the edge of the apron just below the level of the top strap.
    I will have to find out if this difference in the two sides of the apron was the result of an alteration done at some time or something else entirely.
    The second thing this photo points out it the distortion of the fabric where the straps were. There is a very visible bulge in the apron edge and the Tartan lines are not straight any more. There is definitely something going on inside this kilt.
    3rd January 08
    Illinois, USA
    4 Post(s)
    Very interesting indeed. Can't wait to see what lurks inside the waistband of this kilt.
    Member Order of the Dandelion
    7th July 09
    Melbourne,Victoria Australia
    Thanks for this thread Steve. I have recently obtained a kilt made c1954, in Australia, from tartan woven in Australia and is showing some of the problems you have already mentioned. I will be eagerly following this thread to see what you discover
    14th January 08
    San Antonio, TX
    Steve, could the fell edge of the front apron have that "wandering" yellow stripe as evidence of a build designed for a relatively thin waist and a flair of the typically higher than civilian rise to accommodate a larger chest than waist? And what about the two different length buckle holders? Same purpose? Just thinking out loud.
    FM,
    I don't thing we are looking at flair here. Yes, this is an older, military kilt but the waist height is about the same as what we would find on kilts today.
    the extremly high waist kilts you refer to were when the fabric was a standard width and not cut to make the kilt. These WWI type kilts could be unstitched if the hem is torn or if the outside is damaged. They would then be flipped top-to-bottom of inside-out and restitched to give extended wear. By the 1950's when this kilt was made this practice was gone and kilts were made very much like they are today.
    This kilt has a standard 2" rise.
    Also, if you build flare into the kilt is is usual to do it evenly on each side of the apron and in small amounts in each pleat. This give a uniform look to the kilt.
    This kilt has the apron lopsided. This difference side to side of the outer apron even causes the Tartan stripes to skew off to the wearers right.
    The under apron does not show this difference.
    My best guess at this stage is that this is some sort of inexperienced alteration.
    21st March 11
    Hopefully you can open up that first pleat and correct that curve... Looks a lot like something that happened on the test fabric when I first figured out how to machine stitch from behind to keep the stitching invisible - somehow one of my pins only went through the top fold of fabric... When one layer of fabric slipped as I was sewing, it left a very similar curved line.
    Fingers crossed that whoever tried to squeeze so much shaping into one pleat didn't do any chopping.
    I'll be watching this thread very closely.
    5th August 08
    Lancashire, England
    Fascinating stuff. Can't see the pictures yet but I'm looking forward to how this develops and following it more closely when I get home. Cheers Steve. I like these re-build threads.
