17th November 12, 10:49 PM
Double Kilt Hose for Cold Weather??
Call me hard headed, gonna try and post this again and see if it'll take.
Was grubbing out my bachelor cave and came to my soccer sox that some call kilt hose. They're soccer sox to me. Was gonna give them to the local DV Shelter thrift store but then thought they might be good for colder weather. Could wear them under my regular wool kilt hose.
Makes sense - but has anyone ever tried this? Guessing it'd work.
Not cold enough here to try it yet.
17th November 12, 11:13 PM
Makes perfect sense to me! I've never had soneone ask if I doubled sock (or hose). Mowt people are not observant enough to notice and most of the few who do will politely keep their traps shut
The Official [BREN]
17th November 12, 11:22 PM
Cannot tell you how frustrating posting has become...grumble. Okay, on to it yet again.
Did think it through and realize the inside soccer sox "hose" would wind up folded over and become the outside of the cuff...IF they were long enough. A lot of the soccer sox hose seem to be short so it might not be a problem.
It does provide a way to show some creativity with contrasting colors though.
17th November 12, 11:39 PM
A thin liner sock, spandex/wool blend for cool weather, or just 100% wool for when it is really cold makes for a warmer foot. This would be under expedition weight smart wool socks, a bit thicker than good quality kilt hose.
I guess it depends on your shoes, your metabolism and how long you are going to be out in it, but anything you can do to trap more air that isn't circulating around your feet is going to keep your feet warmer. Same for your head, your hands, etc.
What if you put on the soccer socks, and fold them over so they don't show, then put on your kilt hose? Warmer enough?
The two tone cuff idea is intriguing...
18th November 12, 12:49 AM
Aye cousin. Know there are specialty undersocks galore. Was just wondering about using what I had. Probably gonna play with the color thing and length tomorrow...or send them on to the thrift store.
18th November 12, 03:39 AM
Hey Ron.
I virtually always wear some sort of polypro liner with my kilt hose regardless of weather--hot or cold. In cold they help keep your feet even warmer, in heat they may make them a tad warmer but they keep my good kilt hose from soaking up all the sweaty oils and gritty salt my feet give off anyway, thereby making my hose last a little longer in their life. Same goes for heavy cushioned hose for hiking, and heavy winter hose for skiing. snowboarding, snowshoeing or shovelling the driveway---just way more comfortable.
I have soccer socks too, both the lycra nylon stretchy ones and some cotton ones as well, left over from my previous life when my knees and feet were still fully functional and I played defense and goalie for several different teams. It was typical for me to wear one pair of each when I played, mostly for the extra cushioning and slippage between layers that protected my feet from blisters from porlonged and aggresssive wear. Those are relegated to my soccer duffel which has not seen the light of day in a while but will as The Boy comes of age and needs an aging playmate to teach him the ways of the ball, the grass and the goal.
I have never considered nor needed to consider wearing them with my kilt hose, and depending on the combo chosen could see that being unique and stylish or frankly garrish and comical. Try it and take some pictures--maybe it will catch on.
Me. I will stick with my polypro liners and kilt hose--at least for now--and keep the soccer socks for when I attempt a revival of my soccer career.
18th November 12, 10:18 AM
Crack me up, "Garrish and comical"....why not!?
Slow poke here - hadn't even thought of the common sense idea of an undersock offering protection and longer life for the kilt hose...I'm finally figuring out what wiser men do as a matter of course....story of my life.
And, "lazy me" is wondering if an undersock could maybe somehow eliminate the need to wash the wool hose after every wearing....
I don't much like cold weather, but now I'm sort of looking forward to it to experiment with common sense...
18th November 12, 10:40 AM
My first thoughts on this were that doubling up two generally thick socks like that wouldn't fit in most of my shoes. I double up when I go skating, but I usually put some crew socks on over the kilt hose, then take them off when I put the street shoes back on. If I had to contend with really cold weather regularly, I'd think some silk/nylon sock liners would be my speed
18th November 12, 11:05 AM
I worry about how double sox tend to wrinkle up and then make it painful to walk on the wrinkles....would stay thin on the inner pair for sure...or them fancy thin ones that cling to the bod rather than wrinkle up.
18th November 12, 11:45 AM
My winter boots are a full size larger than my summer boots, strictly to make room for more sok, more loft, more trapped air, better insulation.
Generally with the thin lycra/spandex liner socks I don't have to adjust my shoe size.
I hadn't thought of a liner sock as saving wear and tear on expensive kilt hose. Maybe if I ever spring for diced hose I'll revisit that one. Neat idea.
