Results 1 to 10 of 13
    19th May 11
    Albuquerque, New Mexico, USA
    Utilikilt Jean Cut
    I snapped up this NWOT 2007 denim Utilikilt Jean Cut off Ebay mostly because of the rear pockets and it's rarity.
    They are much like the current Original except: it's denim, has the jean pockets in back, has 3 more peats, is selvaged (overlocked) instead of hemmed, it had the no snap "floating" waist band ( I fixed that ) and the underpleating on both aprons is different. ( I also tightened the 3 loose top apron snaps that go through only one layer of fabric - This problem has been around a very long time. It leads to quite a few kilts on Ebay with torn and patched aprons.)
    Discovered this 34x23 kilt has the best action or waggle of any Utilkilt I own, including the denim Workmans. The denim is the same - I measured the thickness. Probably due to not being hemmed and the extra pleats. Maybe as much action as can be expected of a reverse Kinguise pleat system. Of all my Utilikilts, the denims get the best pleat action and lay - probably due to the diagonal flexability of denim.
    The serged (overlock stitched) hem does need the iron after hang drying.
    The pictures - indoors, it's 22 degrees F with a "brisk" wind outside: Front view with all my c**p uh-hum stuff on and in the pockets.
    The rest is without the stuff just the kilt, belt and me. Front:
    Pleat spread:
    Rear with legs out - it takes a lot to open that box pleat - but it opens when walking:
    Sock Color - when I was getting dressed this morning I thought I was going to wear my Caramel UK Workman another day. Then changed my mind - I wanted to see how this one worked in the cold - real good!
    slàinte mhath, Chuck
    23rd April 04
    Portland, Oregon USA
    Looks awesome. Great kilt!
    "Fide et Fortitudine"
    (fidelity & fortitude)
    ALBA GU BRAW!!!!!
    20th August 12
    central Wisconsin
    I have 4 of those denim Utilikilts and yes they are nice kilts
    13th May 13
    Idaho
    Where did you get this denim kilt? I love it.
    25th November 09
    Lomita, CA (via Boston, MA)
    Another very nice denim kilt is depicted here http://www.rkilts.com/blog/index.php.../a-comparison/. I do not own a denim one but I do own Robert's hemp and can attest to the quality of the workmanship. The other thing that is a big deal to me is that the aprons are traditional and not the narrow apron found on the UK.
    19th May 11
    Quote Originally Posted by Starhunter451 View Post
    I think Utilikilt hasn't sold these since 2008.
    I had email notification set up on ebay for about 2 years before a good one in my size showed up at auction.
    I am lucky as my size is common for the teens who don't wear them much (peer pressure) and grow out of them before gaining enough self confidence to wear a kilt. 12 of my 30 Utilikilts are from ebay - almost all near new and never washed.
    Looking good, cool kilt.
    6th July 13
    Deutschland
    I think of denim as pretty stiff compared to cotton drill fabrique, so it is less prone to wrinkle. Who is this guy called Kinguise?
    19th May 11
    Quote Originally Posted by cryptoman View Post
    Kinguise is a town/district in Scotland where the pleat system was first seen. It is spelled a bit different I think.
    Denim, when new, has a lot of sizing in it that makes it stiff. There are also several different weaves of denim.
    A trick I use on new denim and on the cotton ducks, is, after they have been hang dried, I toss them in the cold dryer for 10 minutes with a dozen clean tennis balls. It makes the denim diaper (nappy) soft without any apparent harm. On the ducks, it reduces the stiffness and abrasiveness - some.
    These broken in Utilikilt denims seem totally immune to wrinkles.
    6th July 13
    Deutschland
    I envy your flat underbelly, it makes kilts look superb on your waist. I recently bought a Biker Skilt with extra thikness on the waistband. Is cotton drill really that rigid? The adjustable waistband sounds good in theory but make the adjustment a pain in the ***. As long as I cannot bend over properly I think the extra stiffness makes it unwearable to me.
