Rory: I have a 41" "natural waist" and use sporran belts that are 47" - 49" in length. They leave plenty of room for adjustment. If you error, do so in the direction of "too long". At worst you can always cut it down. Good luck.
John
My rule of thumb is to go about 4" larger than your natural waist, so that would be 50" in your case. But most all sporran belts I have ever seen have been adjustable several inches in either direction. So once you get in the ball park you can fine tune it to suit your size and shape.
Matt
John
Matt
Yup, what they said.
When I'm making straps I use their KILTED waist size, add 4-5" for the 'drop' on the sporran strap (depending on the overall waist size), and then a tiny bit of overage for adjustability and the strap-end.
Oops, it seems this member needs to update their email address
5th April 13
Hmm... is DIY with a hide (or a belt blank and a bottle of dye), a Strap Cutter(tm) and a punch completely out of the question? If I ever resume a long-ago handmade sporran project of mine, I'm doing none other for the sporran strap. It's a daywear sporran, of course. Something more formal would await more experience.
