20th April 13, 05:37 PM
Moving buckles to make a kilt smaller or larger
Hi all,
XMarks gets many posts asking what to do if a kilt is either too small or too big. Because the answers are buried in individual posts, I thought I'd make a thread that explains what to do.
The easiest thing to do is move the buckles. Although it's possible to actually alter the kilt, alteration requires taking the kilt apart and rebuilding it. This is a big job and not something that most people can do themselves. Moving buckles and straps, on the other hand, is something that anyone can do.
First, I'll give instructions for moving buckles and straps, and then I'll comment on how much is "too much". The instructions below are slightly different for a kilt with a traditional "buttonhole" (where the strap comes through the pleats) and for a kilt with a "hidden" apron strap and buckle (which is a common configuration in box pleated kilts).
THE INSTRUCTIONS
For a kilt with a traditional buttonhole:
Buckle(s) on the fringe edge: Carefully snip the stitching around the cloth tab that holds the buckle on the kilt. Move it toward the back of the kilt to make the kilt smaller, or toward the front of the kilt to make it bigger. Sew the tab back on using heavy thread through as many thickness of the kilt as possible without stitching all the way through the lining. I use Coats and Clark Button and Craft thread. If you have tartan scraps, you can replace the cloth tab so that it matches the tartan in the new position.
Buckle next to the buttonhole (where the strap comes through): Don't move this one (moving it doesn't accomplish anything).
Strap(s) on the fringe edge of the apron: Don't move these either.
Underapron strap: Carefully snip the stitching that holds the underapron strap. Move it toward the underapron center to make the kilt smaller, or toward the edge of the underapron to make the kilt bigger. If you want to make the kilt bigger and the strap is already on the edge of the underapron, your only choice is to replace the strap with a longer one. Sew it back on using button and craft thread, sewing through as many thicknesses as you can without stitching through the lining on the inside.
For a box-pleated kilt without a buttonhole:
Buckle on the fringe edge: Carefully snip the stitching around the cloth tab that holds the buckle on the kilt. Move it toward the back of the kilt to make the kilt smaller, or toward the front of the kilt to make it bigger. Sew it back on using heavy thread through as many thickness of the kilt as possible without stitching all the way through the lining. I use Coats and Clark Button and Craft thread. If you have tartan scraps, you can replace the cloth tab so that it matches the tartan in the new position.
Buckle on the underapron: remove the buckle and tab as above. Move it toward the underapron center to make the kilt smaller, or toward the edge of the underapron to make the kilt bigger. Sew it back on using button and craft thread, sewing through as many thicknesses as you can without stitching through the lining on the inside. If you have tartan scraps, you can replace the cloth tab so that it matches the tartan in the new position. If you want to make the kilt bigger and the buckle is already on the edge of the underapron, you can move the inside (underapron) strap instead (moving it toward the front of the kilt).
HOW MUCH IS TOO MUCH??
If a kilt has gotten too small, it's really obvious because the unpleated underapron shows beneath the fringe edge of the apron. So, depending on the buckle placement of the original kilt, moving buckles to make a kilt bigger is typically not a very forgiving process. On the other hand, making a kilt smaller can soak up an amazing number of inches. On an average size kilt, moving buckles several inches to make the kilt smaller is not even noticeable, because the apron just covers up a few pleats.
So, how much is too much to move buckles? Even an inch of expansion is likely to be obvious. On the other hand, many inches of contraction is easily hidden. Awhile back, I made a post showing a kilt where I moved the buckles 11", and it's still not obvious. The post (http://www.xmarksthescot.com/forum/f...oo-much-59745/) shows that the person is a large person, but it makes the point!!
