Results 1 to 7 of 7
    7th February 08
    Abbotsford, BC, Canada
    stitch-up bottom of inverted pleat?
    it looks like the bottom of the inverted pleat ( on the kilt I'm currently making) may hang down, below the bottom of the kilt - should I stitch it up, like the deep pleat? ( i can wait and see, but just wondering if this might be something missing from TAoKM?)
    ... should I stitch it up, like the deep pleat?
    I believe the answer is yes.
    19th May 08
    Oceanside CA
    What Barb had to say, a while back
    Not sure which pleats you are describing, but I'd feel free to slightly hem anything that made me go "hmmmmm, I wonder. . ."
    The little ends of both the deep and the reverse pleat do tend to hang below the hem. This is due to the apron taper.
    Both of these "apron tips" should be hemmed up.
    Please see this post by Barb.
    http://www.xmarksthescot.com/forum/s...ad.php?t=40778
    7th February 08
    OK< thanks, everyone ; & yes, I did read all of that, but there does not appear to be anything specifically addressing the inverted pleat, BUT, it does "follow", that if it shows below the bottom of the kilt, them I'll stitich it up - later
    I don't typically do it, because it doesn't typically hang below. But there's no reason why you can't if it does stick out.
    Both of these "apron tips" should be hemmed up. Please see this post by Barb. http://www.xmarksthescot.com/forum/s...ad.php?t=40778
    This post actually only shows turning up the deep pleat, not the inverted pleat. The inverted pleat is typically shallower than the deep pleat and, hence, is less likely to show. But, as I said above, there's no reason that you can't stitch it up if it shows. I've never had an issue with it, actually.
