Apron Looser than Underapron
I'm just about to put the lining in my very first kilt and I had to try it on for fit. I found that the underapron strap was just about perfect - it fit snugly on the middle hole of the strap. But when I wrapped the apron around and buckled it, the apron was loose until the strap was on the last hole, and then it fit snugly. It seems that the apron buckle or strap needs to be moved, but if I move the apron strap in towards the center front, a couple of the last holes on the strap will be covered by the fringe edge of the apron. My question is, should I move the apron buckle farther around the back deeper into the pleats? Right now the apron buckle center is on the last pleat before the underapron. I'm worried that if I lose a few pounds, then the apron will be too loose and I won't have anywhere to go to tighten it. I'm just looking for a little advice on this before I move on. Thanks in advance!!!
Rob
