Results 1 to 10 of 15
    3rd July 13
    Melbourne Victoria Australia
    A comment about creating links
    Maybe it's just my "inner geek" showing, but I've noticed that most links in people's posts are of the form:
    http://www.google.com.au/
    Are the rabble aware that it is actually easy to create a more descriptive link?
    As in:
    Google
    Both of the above are links to Google Australia, but I'd suggest that the second looks better.
    So, how did I do the second one?
    1. Find the link that you want in a different window or tab in your web browser
    2. Type the text that you want to have visible for the link
    3. Highlight the link text by dragging the mouse over it
    4. Click on the link Icon in the compose message tools
    5. Insert the URL into the box provided -- what I actually do is to use copy and paste
      1. Go to the tab or window where the page you want to link is displayed
      2. Highlight the the URL in the navigation window of your browser (Most browsers will
        display the URL by default, if it isn't there, you should be able to add this to the
        toolbar by using the browser's options menu.)
      3. Copy ( Ctrl/C or butterfly/C on a Mac)
      4. Paste in the URL box ( Ctrl/V or butterfly/V)
    Voila!!
    Note that this does not actually conceal the URL, as the browsers that I'm familiar with will show the
    destination URL when you put your mouse on the link. Just makes things look a bit neater and potentially
    gives a clearer statement of what you are trying to show. The improved link that I provided at the start
    of this post is still clearly a link since it is in the "link style". (Underlined -- might be better if links were a
    different colour, but it still looks like a link)
    I hope that this is useful to others.
    And to you, Jock, a big thank you for asking for more detail -- I hope that this is useful to you.
    -Don
    And a couple of definitions -- Ctrl/C is a way of showing the key on the keyboard with the letters
    Ctrl (for control) printed on the keycap and the letter C key -- so that means press the two keys together
    (like shift - c to get C)
    URL - means a Uniform Resource Locator -- AKA web address
    butterfly key -- I'm not really sure what to call this, but on an Apple computer the key that I'd call a Control key
    has a funny symbol on it This is a link to a picture and description of the key - it is used like the Ctrl key on a PC
    Note that I'd normally use Greater-than/Less-than around the key cap names, but I'll admit that I'm stumped--
    there is no way to get the display system to just display the characters represented by HTML codes and the
    characters just disappear when I tried to use them
    Last edited by Aussie_Don; 29th July 13 at 10:21 PM. Reason: Further detail and pictures, at the request of Jock Scot -- and now linked to external images so they are big enough to read
    15 Post(s)
    I am sure all of the above is very usefull and I would very much like to create links as they are a very useful tool. Sadly I do not understand a word of your technojargon, is there a chance of you interpreting it in words of one syllable for us technodunces?
  3. The Following User Says 'Aye' to Jock Scot For This Useful Post:
    14th October 10
    Los Alamos, NM, USA
    Don: It's good of you to go to all the trouble to describe how to create a meta-link, and your instructions are excellent - correct, clear, complete, instructive, and illustrative. Personally, I hope they are made a "sticky".
    But, they also dramatically illustrate why I rarely choose to do so. It is much easier for me to just copy and paste a url and then write something like ...
    If you want to see something really cool, just click on
    /www.whatever/it/may/be
    John
  5. The Following 3 Users say 'Aye' to mookien For This Useful Post:
  6. #4
    15 Post(s)
    Crikey Don, thank you! I will give it a try----------- and after I have studied your super set of instructions,-------- you never know in a month------- or-------- three I may have worked it all out!
  7. #5
    7th July 09
    Melbourne,Victoria Australia
    In the same boat Jock, thanks Don for the brilliant instructions but to this computer sloth they are as clear as
  8. The Following User Says 'Aye' to Downunder Kilt For This Useful Post:
  9. #6
    25th November 10
    Nimes, South of France
    It's really relatively simple (it's probably the "relatively" that scares people!). Let me see if I can try to translate. Firstly you have to open a new tab (window) on the site you want to link to and copy the address from the address bar. Copy this by pressing the keys Ctrl and C at the same time.
    Then, back on your post on XMarks, type in some text which you will use as and indicater of your link (example 'Click Here for Haggis') then select (underline) this (which covers the text in blue) by pressing MAJ and dragging the mouse over the text.
    Once this is done, click on the icon (in the XMarks reply box which you are using) which is in the shape of a globe with a small sideways 8 on the bottom. This will open a window. All that is left to do is to paste the previously copied address (where you pressed the Ctrl and C keys at the same time) by pressing the keys Ctrl and V at the same time.
    Easy, isn't it.
  10. #7
    3rd July 13
    Quote Originally Posted by BCAC View Post
    the address bar.
    With you so far
    I am assuming that MAJ is the French equivalent of "Shift" (A hangover from typewriters when the shift
    key really did shift the innards where the little levers with the type were.)
    Easy, isn't it.
    I'd have liked to show the mouse on the link icon, but unfortunately, my screenshot program "helpfully"
    removed the mouse pointer from the screen picture.
    Thanks for your comments -- I'll try to see if I can incorporate them in the original post to make it
    more useful.
    -Don
  11. #8
    25th November 10
    Don, sorry, but of course you're right. MAJ is the French equivalent of Shift. My apologies.
    Perhaps you could now explain the multi quotes?
    I used to have this possibility. There used to be an icon on the bottom right of all posts in the shape of quote marks with a + sign, but this is no more?
  12. #9
    19th September 12
    Highland, IN
    You can also simply type it like this:
    [ URL="http://www.google.com.au/" ]Google[ /URL ]
    Without the spaces, though. It may seem more complex, but it's honestly less steps and easier once you get the hang of it.
  13. The Following User Says 'Aye' to Llama For This Useful Post:
  14. #10
    14th September 05
    Space Coast, FL
    2 Thread(s)
    And FYI, if you want to show somebody exactly what they need to type, but prevent the forum form interpreting the tags, just place the noparse tags around it, like this
    [noparse]
    [URL="http://www.google.com.au/"]Google[ /URL]
    [/noparse]
  15. The Following 4 Users say 'Aye' to KiltedCodeWarrior For This Useful Post:
