Results 1 to 10 of 14
    7th February 11
    London, Canada
    Alternative source for a leather punch?
    Good day all!
    For years, I had a marvellous leather punch which made four evenly-spaced round holes. When we moved back to the city, I couldn't find it and purchased the tool shown in the picture from Tandy.
    Sadly, it has proven most unsatisfactory - after some really light use, it is now so dull that it won't even punch 3 oz leather. Further, the holes are a tad smaller than my old wonderful tool used to make.
    Now Tandy have shown absolute integrity and are shipping me a new one with no argument whatever so it's hard to grepse, but of course it's the same tool and I fear that it will shortly prove useless as the other one.
    Can you leatherworkers point me to another source where I might have better luck?
    Bill+
    13th May 14
    New Kent, Va.
    I got a larger center punch from Sears and put it on the grinding wheel to square up the punch, and use that for making stitch holes. it's only one hole at a time, but makes a nice one
    3rd March 10
    43*N 88*W
    Hey Padre- Part of the issue may be Tandy's rather shoddy metal quality.
    You might be able to find the punch heads from a different source, and select a larger size of punch to boot.
    Check HERE to see if they have what you need.
    ith:
    7th February 11
    London, Canada
    Thanks a million, Scott; I'll keep that one for a follow up in the very near future!
    26th February 12
    Lake in the Hills, IL
    38 Post(s)
    I Cryo treat all my edged tools, helps amazingly in the department of holding an edge, I have cheap kitchen knives that are insanely sharp and since treating stay that way for quite a long time
    "Everything is within walking distance if you've got the time"
    25th November 13
    Birmingham, AL
    Cryo-treating metal is a method employed to remove retained austenite and untempered martensite from the microstructure. It doesn't actually remove it - it transforms it to a more stable, less brittle form. Just a little tip from your friendly neighborhood heat-treater! We usually do that anywhere from -150*F to -300*F but in this case, if you've access to a deep freeze, that should work well enough.
