14th September 14, 04:52 PM
Wrapping the Braveheart kilt
I am working on a production of MacBeth in which the director wants the kilts worn in the "style of Braveheart" with the top apron pulled up under a belt in a narrow band and fastened on the shoulder. I've looked at the pictures, but I can't reproduce the wrap... Anyone have a tutorial on this?
15th September 14, 01:44 AM
There are a number of tutorials online, the details vary but they are all pretty much the same in essence. For example-
Just Google "how to wear a great kilt" or "how to wear a feileadh mòr".
You will require approximately 9 yards of single width fabric cut in half & stitched together to make a piece of cloth roughly 4.5 yards by 2 yards. Or alternatively, approximately 4.5 yards of double width fabric.
15th September 14, 01:53 AM
Alternatively check out a matchcoat.
http://wildeweavery.com/matchcoats.htm
The wearing of a blanket in this manner has a very long and well documented history.
If we accept that the Great Kilt has its beginnings as the leine and brat,
If we accept that plaide means blanket,
and if we accept that it was supposed to be an all purpose garment,
this is probably much more realistic.
Whenever I see those directions that have you laying 18 feet of modern fabric out on the ground and laying on top of it,
All I can think of is -
What is the first thing you have to do when you wake up?
If this was supposed to be your sleeping blanket and it took that long to get dressed - Do you really want to go through all that laying out of fabric, laying down and arranging "The whole nine yards" of modern kilt fabric just to go to the latrine?
Try it for yourself. grab the blanket off your bed and wrap up in it like you see pictures of American Indians. Simple, easy, practical and historically correct.
15th September 14, 02:17 AM
The kilts in Braveheart are not the great kilt but something strange and new.
They look like a 'small kilt' - that is a modern one BUT with the aprons reversed, so the apron on the right side is uppermost and it is also extended so it goes across to the left hip and then is rolled or folded and turned through 90 degrees so it can be held under the belt as it goes up and over the left shoulder.
I suggest that the kilt is made with a band on the inside (I use military style webbing) to which the fabric is attached - starting at the right hip with the under apron, then simple untailored pleats and then a strong fastening on the webbing so there is a firm foundation to the costume. The over apron and extension can then have the turn and folds created and sewn in at the point where it goes under the belt, so the kilt is buckled on, the extension thrown over the shoulder and belt fastened over all to hold it in place. Belt loops might be an idea so that the belts do not become separated - or pierce the belt and fix it at each end of the row of pleats with a loop of cord to the waistband, which can also be used to hang it up.
15th September 14, 02:57 AM
It appears to me that matchcoats and great kilts fulfill pretty similar functions, though I don't believe that they are the same thing.
I think the evidence suggests that great kilts were about 4-6 yards (12-18 feet) long, and I suspect the reason they would have been that long would have been to provide sufficient material for warmth when used as bedding. I doubt they would have been carefully pleated when put on, more simply scrunch up, slip the belt under, lie down, buckle up, stand up. Yes, it's more of a faff than we are used to, but it's not actually that bad. I've tried it.
Note that the very earliest box pleat kilts were about 4-5 yards long. They were simply the bottom half of a great kilt with the pleats stitched in.
http://www.scottishtartans.co.uk/Joined_Plaids.pdf
http://www.scottishtartans.co.uk/Two...ish_County.pdf
http://www.scottishtartans.co.uk/The_Dunollie_Plaid.pdf
http://www.scottishtartans.co.uk/Unn...ethybridge.pdf
The few remaining complete plaids from the 18th century seem to me to suggest 4-6 yards was typical.
The Following User Says 'Aye' to Calgacus For This Useful Post:
15th September 14, 03:50 AM
It seems to me that the costume designer for Braveheart saw various images of Highland dress showing
-the 'great kilt'/'belted plaid'/'philamore'
-the modern kilt/small kilt/ 'philabeg' worn with a separate 'long plaid' wrapped around the body
and, not understanding that he/she was looking at two quite different forms of dress, and assuming that all the images were showing the same thing, tried to make sense of it all and created a hybrid thing which, in fact, doesn't make any structural sense.
Too bad that now people are looking at the costumes in that movie as a guide to doing early Highland Dress.
At an early period there would be two forms of Highland Dress worn by people with the money to afford nice clothing
1) tartan jacket and trews, with a long plaid (simple rectangle of tartan) loosely draped around the body. These four items were often in different tartans.
2) tartan jacket and great kilt/belted plaid/philamore and patterned hose. These four items were often in different tartans, the hose usually being red & white.
The jackets could also be plain. Waistcoats were sometimes worn.
The great kilt/belted plaid costume in 1710. The slashed doublet would have been quite old-fashioned at that time.
We don't have good portraits of periods much earlier than this, so these early 18th century portraits will have to serve.
The trews & long plaid costume
One can see that the plaid wrapped around the body isn't worn with the kilt in the early period, the great kilt/belted plaid/philamore being quite sufficient on its own.
Now here we are a century later, in the early 19th century, with the small kilt worn with long plaid wrapped around the body. This costume is obviously anachronistic to MacBeth, Braveheart, Brigadoon, etc but nevertheless it's this sort of 19th century costume that Hollywood costumers seem to always have in mind
15th September 14, 04:31 AM
Thanks for your responses. I agree that is it not a traditional approach... it just happens to be what is needed for the moment and if it will require any cutting on my plaid, then it isn't going to happen!
That said, I parsed through the movie last night and found a scene where Mel is being dressed by his wife. He is already belted and all of the extra material is somehow gathered on his right hip. It appears she is tying it at his waist to secure it, then she passes it across his chest in a thin band and over his left shoulder.
That said, that is the look I am trying to achieve. The material in a band across the chest, rather than covering it. I have seen this numerous times online and at games so there must be a way to achieve it, but I'll be darned if I can figure it out.
15th September 14, 04:40 AM
Of course the historical accuracy of all this is a bit of a moot point because Macbeth predates the wearing of kilts at all. The historical King Macbeth reigned in the 11th century when, if anything, highland dress resembled Irish dress, namely leine & brat. The play was written around 1600, just at the point when the earliest images of the belted plaid were produced.
Highland dress pre-belted plaid (1577)
Earliest illustration of a belted plaid c.1605
Earliest c1605 by Richard the Rogue, on Flickr
Early illustration, 1641 woodcut
1641 woodcut by Richard the Rogue, on Flickr
Reason: Added image
15th September 14, 04:50 AM
Sascha_Bohl_2.jpgThe Celtic Croft sells what they call the Ancient Kilt. From their website: "The Ancient Kilt is basically a Phillabeg with an extra 2-3 yards of tartan attached. The extra tartan is there to be worn as a sash or a fly plaid, once the kilt is pleated. It differs from the Great Kilt because it is made from a longer piece of single width fabric (25 – 30 inches wide)."
"Don't give up what you want most for what you want now."
Just my 2¢ worth.
15th September 14, 07:06 AM
Duke,
Are you saying that this is more than just 5 yards of 60 inch plaid? In other words their is a thin strip at one end that extends a few more yards?
