Results 1 to 4 of 4
    22nd October 04
    Wuppertal, Northrhine-Westfalia, Germany
    Unhappy RŽLyeh Sett waistband
    DSCF2993.jpgAfter having it lying around for years I finally started on my RŽlyeh kilt made from the first run by Dalgliesh.
    I need it 26 inches long and I had to discover the width of the material is only 53 inches.
    I HAVE NO MATERIAL FOR THE WAISTBAND!!!
    HELP!! Does anybody still have a leftover I could have??
    PLEASE!!
    "Wizards in trousers? Not in my university! It`s sissy. PeopleŽd laugh." said Ridcully.
    Christian Pipe Smoker
    My Youtube Channel
    I can't help with the fabric, I'm afraid, but having found that I had made a mistake with a waistband cut across the warp threads I sewed the top of the kilt onto the webbing which is the reinforcement for all my kilts at the waist, then put black ribbon over the raw edges and sewed it top and bottom. Top to the webbing, bottom to the pleats.
    Here's a photo of the apron, red ribbon and khaki webbing reinforcement inside and the black ribbon outside.
    Military kilts used to be bound with the same stuff they used for the edges of horse blankets - which was green, no matter what the tartan.
    You could use green, black - even purple.
    I think that you should cut the fabric in exact halves - assuming that the set is exactly placed so it matches, to compensate for the lack of anything extra at the waist. The photo shows that the fabric is barely 53 inches - otherwise I would have suggested cutting that spare inch very carefully and sewing a narrow ribbon one side of it, and a broader one on the other, then sewing it so as much of that one inch shows as possible. The broader ribbon is for the inside of the band. Usually woollen fabric is 54 inches wide but with a custom weave and 'designer' tartan - obviously nothing is set in stone...
  3. The Following User Says 'Aye' to Pleater For This Useful Post:
    15th April 07
    State College, PA
    I'd go with some green. Not to worry, just tell everyone that it is a soldiers top band type kilt...
    Wallace Catanach, Kiltmaker
  5. #4
    Ah - actually that's the under apron - and the colours are altered by the gloss on the ribbon - I chose the black and the red as they are in the tartan. I have quite a stock of ribbon to chose from.
